Question about Kyocera Fs-1300d Printer
PCL XL error Warning: IllegalMediaSource error
HP L7680 Error
GOOGLE IS YOUR FRIEND IN SUCH CASES :) Excuse Caps. Your Drivers need updating, but you are seriously hampered because all support for XP ended ages ago. Why are you still running Windows XP leaving your computers open to security breaches? You should be on Windows 8 Pro at the least or Windows 10. What I would do is go to the HP Website and download and install the drivers and software again.
Search Results PCL XL Error. The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to the printer's print queue. ... HP has identified the problem printer drivers for most of their printers that display the PCL XL error.Mar 11, 2016
PCL XL Error - The Tech-FAQ
www.tech-faq.com/pcl-xl-error.html Feedback
About this result
How to Fix PCL XL Error ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-pcl-xl-error Mar 31, 2015 - When attempting to print certain documents on a Hewlett-Packard LaserJet all-in-one printer, you might sometimes end up with a piece of paper with a "PCL XL" error code printed on it. This is due to the printer's inability to process certain parts of the document, such as embedded fonts or images.
Solved: PCL XL Error and other weirdness - Customer Support Forum
forum.support.xerox.com/t5/Printing/PCL-XL-Error-and-other-weirdness/td.../164 Sep 17, 2010 - 10 posts
Hi all,. We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 ...
PCL XL error in printer - Microsoft Community
https://answers.microsoft.com/.../pcl-xl-error.../124223ac-bd82-4758-8d7f-7efe95a04... Nov 11, 2013 - I have a HP LaserJet 4250 PCL6. I was trying to print and all of a sudden I am getting an error message. ... c:\ windows\system32\spool\printer\X64\3 rename the file relating to your printer with the .gpd extension - call it anything you wish and then reboot your pc and it re-creates ... PCL XL error: IllegalOperatorSequence
3 Dec 2016
PCL XL error - Subsystem: IMAGE - Error: IllegalAttributeValue ...
13 Jul 2016
Getting PCL XL error when trying to print.
30 Dec 2012
When trying to print, get a page that has message PCL XL Error ...
28 Dec 2012
More results from answers.microsoft.com
Troubleshooting: PCL XL Error - Customer Support
https://stamps.custhelp.com/app/answers/detail/a.../troubleshooting%3A-pcl-xl-error Next, you will need to install the "PCL" or "PCL 5" version of your printer's driver. This driver should already be available on your computer or the CD that came with your printer. It can also be downloaded from the HP website.
www.tech-faq.com/pcl-xl-error.html Rating: 4 - ‎4 votes
Mar 11, 2016 - The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to ...
PCL XL error Google Search
Jul 25, 2017 | Office Equipment & Supplies
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
PCL XL ERROR - ILLEGALMEDIASOURCE
I would advise trying to use the PCL 5 Driver - I presume that at the moment you are probably using the PCL 6 driver.
If you need any further infor please post back with a little bit more info!
Aug 23, 2009 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
PCL XL error when i give command to the printer from my pc, i get the following error PCL XL error Subsystem: KERNEL Error: IllegalTag Operator: Oxlb Postion: 6
I already answered this, but the response did not get posted.
The short answer is that the PCL XL interpreter has picked up the use of the "Escape Code" (0x1B) in the incoming datastream. This command is used for the standard versions of PCL, most notable PCL 5e. It is not used in the PCL XL datastream.
Don
Aug 16, 2009 | Office Equipment & Supplies
Pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
Sep 19, 2008 | HP LaserJet color laser printer
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
Jul 28, 2008 | HP LaserJet 3050 All-In-One Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Kyocera Fs-1300d  Printer Logo
1,025 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
George Mclaughlin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
