Question about Ricoh Office Equipment & Supplies
MP7001 - SCAN FILES ARE BEING SENT TO EMAIL AS A DAT FILE INSTEAD OF PDF
  • 27 Answers
Press the Scanner button, on the left hand side of the LCD screen there should be a button that says "file type" press that and change the current setting to multi-page PDF. Now press ok and you should be back to the main scanner screen. on the right hand side of the control panel above the numbers press the program key, now on the LCD screen press program as default a window will pop up asking if thats really what you want to do, just press yes and you should be good to go.
Posted on Dec 17, 2009
You must concatenate the .dat files with the software "hjsplit". You have to rename the dat files, like this : *.001, *.002, *.003 ..etc .... After, you obtain one file without extension. To extract your initial scan document, use the software "Stuffit Expander" ..... and it s good !
Posted on Mar 21, 2012
Why are jpg attachments showing up as winmail.dat files on my iPhone?
I haven't seen much directly relating to jpg formats becoming winmail.dat files, but it seems with the new iphone ios7 operating system, many other types of RTF and PDF sorts are coming in as winmail.dat files and who's to blame at the moment might be unknown. Some blame Microsoft while others are isolating it down to the new ios7.
I'll keep looking but this is what i found so far...
Winmail dat attachments
Feb 08, 2015 | Apple iPhone Smartphone
Cannot open pdf file in email
This is a known issue with users sending PDF's using Microsoft Outlook. The link below gives instructions on how to change on their end.
Link:
PDF file changed to DAT file on receiving end when using Outlook in...
I also found a solution that might work on your end...This is from a blog post on the Apple forums.
This is a common problem.
I have found a converion web-site www.winmaildat.com, where you upload the problem file, and it is automatically 'deciphered', and the contents can be downloaded in their individual files.
Dec 05, 2012 | Apple MacBook Air
Ricoh mp7001 stopped emailing but still can scan to server. ??
You're asking if this is possible? Yes, it is possible. They are two different things. To scan to email use the SMTP server. To scan to server only need the folder path and authentication
Jan 25, 2011 | Ricoh Office Equipment & Supplies
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
How do i read .dat files that i receive by email
If these files are forwarded email messages, you can try this trick: save the .dat file to your disk, rename it with an extension .eml instead of .dat and then try to double click it. OE should open it in a new window.
However, if the .dat files are something else, you have to know what they are... Might try saving them and opening in Notepad to see if they contain anything familiar.
Oct 25, 2009 | Microsoft Outlook Express
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Sent mail is no longer being saved in sent folder after upgrading
For the extend.dat, Microsoft does not have a solution yet. Please refer to the link below:
http://support.microsoft.com/kb/287844
Try the steps at the link below to solve the sent email issue:
http://support.microsoft.com/kb/287497
Mar 25, 2009 | Microsoft Office Outlook 2007 for PC
PDF Files When Scanning with X4270
If you can reduce your scan resolution (e.g. 150 DPI instead of 300 DPI) or color depth (scan in black and white instead of color) it will result in a smaller PDF.
Steve
Feb 25, 2009 | Lexmark X4270 All-in-One Multifunction...
Ricoh Aficio 2090 Printing config question
You have to scan each one individually. The machine can scan them into a pdf file. Press user tools button. Press the scanner button and check the file format settings for individual files. Select PDF if needed.
Nov 13, 2008 | Office Equipment & Supplies
I need my scanned documents to be in pdf file. it wants to sent it as a paint document
It is advised to go to the Brother web site and download the http://www.brother.com/E-ftp/windowsvista/asia.html brother original drivers. Once you follow the instructions on the drivers you can then install new complete driver which allows you to choose various files.
Hope this helps as I had the same problem
Please open the Brother Control Centre software, go in to the configuration and then to scan and then the scan option you are choosing (email, file etc) there will be a file type option here and one of the options will be PDF.
Jun 02, 2008 | Brother Office Equipment & Supplies
1,197 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
aaron douglas
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
