Question about Intel Motherboard
Motherboard ram Hi i'm looking for a manuel for my Asus motherbord A7V-266 with a Athlon Xp 1700+266 socket because i want to know how much DDR ram i can put in it (maximun)...thank you!
  • 1 more comment
  • Rouyn Jan 19, 2008
    That was fast...thank you very much...
    1gb per slot and don't mix 333mhz and DDR 400 together, use same thing for the three slots....right?
  • Anonymous Mar 02, 2008
    Just need diagram to connect case wires to motherboard as the board only has coloured connections not named as I am used to
    Genius:
  • 1,067 Answers
3 gb 3 slots 2 gb 2 slots on these xp ok new xp 64 chips can do sumtiems more
Posted on Jan 19, 2008
  • 1 more comment
  • nick helpap
    nick helpap Jan 19, 2008
    ddr 333mhz also dont need ddr400 ok
  • nick helpap
    how much ram u have now
    i owul max it out 1 gb per slot max ok
  • nick helpap
    u can mix it but it will lower the ddr400 to slower ones ok and sumtimes that dont work if that ddr400 is ddr400 only and not backwards to 2700 speed ram and 2100 speed 266mhz and 333mhz and 400mhz is ddr400 ok pc3200 use
    pc2700 333mhz 1 gb per slot low density chips samsung on ebay 35 eash
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Memory upgarade
    Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
    Jul 21, 2009 | ASUS A7V400-MX Motherboard
    Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
    i could only fins thease specs for you
    AMD Athlon up to 2400+
    AMD Athlon XP up to 2600+
    AMD Duron up to 1.8GHz
    Jun 29, 2009 | Syntax SV266M Motherboard
    Compatiblity issue..
    You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
    This is from your manual:
    Dual-channel DDR400 memory support
    Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
    If you would care for the manual, here is a link:
    Asus P5P800-VM Manual
    Thanks for using Fixya.
    Apr 03, 2009 | ASUS P5P800-VM Motherboard
    Can't use two of 512 ddram in ecs m925
    Check the following:
    The fsb are the same, if this differs it could couse instability.
    ( do not use 266 ram with 333 ram and 333 with 400 , or any other mixture of thease).
    try this: pull out the rams and put back the first to the second's socket and the second to the first's socket.
    Good luck.
    Dec 15, 2008 | PC Chips (M925G) Motherboard
    Type of ram
    ASUS A8N-SLI Premium Specifications
    CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
    Chipset: NVIDIA nForce4 SLI
    Front Side Bus: 2000/1600 MT/s
    Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
    Expansion Slots:
    2 x PCI-E x16
    - SLI mode: x8, x8
    - Default (single VGA): x16, x1
    1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
    3 x PCI
    Storage/RAID: nForce4: 4 x SATA 3Gb/s
    NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
    2 x UltraDMA 133/100
    Silicon Image 3114R RAID controller
    4x SATA with RAID0, 1, 10, 5
    Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
    LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
    or see this site:
    http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
    Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
    DDr or Dual Channel Ddr
    From the manual:
    2 x 184 pin DDR DIMM Sockets support up to maximum 2 GB unbuffered PC 2700/2100/1600 non-ECC DDR SDRAM memory.
    So, to answer your question, for your particular motherboard, no. However, to dispute the other poster, Dual channel is better than regular DDR. It's just your motherboard does not support it.
    Jul 03, 2008 | ASUS A7V400-MX Motherboard
    MPN: A7S333
    Form Factor: ATX
    Width: 30.5 cm
    Depth: 21.9 cm
    BIOS Type: Award
    amd 3200 + anthlon ok with fsb 266 mhz soket a
    Intel Motherboard Logo
    41 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
