Question about Desa International PROPANE PATIO HEATER TABLE
I need a Desa thermocouple #118906-02 can you tell me where to buy one
When I push the setting dial down and push the iginator control button the flame starts, and when I release the dial knob the flame goes out and that is on Model # CBN 301 DESA Blue Flame Custom Glow
It sounds like your thermocouple either needs to be cleaned or replaced.
I would start by cleaning the thermocouple first.
Here is a link to the instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Oct 17, 2011 | Desa International Blower Glow Warm Wall...
Trying to find a replacement thermocouple part assembly for a univeral 30 fas propane heater
You can find the part at http://www.masterparts.net/
But, you need to have the exact Model Number of your heater. Not just what you had listed in the question.
Hope this helps you get back up and heating.
Mar 09, 2011 | Heating & Cooling
THERMOCOUPLE BAD ON MY REDDY HEATER MOD#TB101 CANT FIND PART # FOR IT
The Part # for the Thermocouple is 104146-05.
Keep in mind, DESA International is no longer in business, but I think you can find it at
www.reddyrparts.com
Feb 01, 2011 | Desa International TB101 Heater
How and where do I replace a thermocouple on a warm glo wall furnace? Help
There should be a thermocouple in front of the burners that has a copper colored wire that runs from the gas valve to the thermocouple. It is located in the pilot flame as it is a pilot proving switch that tells the gas valve the pilot is lit and its okay to open the gas valve to the main burner.
Mar 21, 2010 | Desa International Blower Glow Warm Wall...
DESA Propane Heater Valve Apart
Do,not override the safety features on any units unless youre qualified. These are not overides ,but safety switches to tell when something is not right! Anyway, its time for a fall service overhaul or kit ---plug---fuel filter---2 air filters --clean the flame sensor---and vanes in the pump replaced.You can buy the kit and parts that you need a your local lawnmower repair shop or have them to order them!
Dec 14, 2009 | Desa International Propane Portable...
Desa unvented propane log heater pilot will not stay lit
check to make sure that the end of the thermocouple is in the flame. This is the hot junction of the thermocouple and it the difference in temp that create the millivolts to operate the gas valve. If it is in the flame, replace it and if a new thermocouple doesnt fix it, you need a new gas valve
Dec 09, 2009 | Desa International Heating & Cooling
Desa direct vend fireplace pilot goes out when i let out on pilot
There is a pilot safety called a thermocouple. I bet it needs changing. Look for a small probe that is located in the pilot assembly.
Nov 27, 2009 | Desa International Blower Glow Warm Wall...
Desa International PROPANE PATIO HEATER TABLE Logo
253 people viewed this question
Top Desa International Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Desa International Pool and Spa Expert? Answer questions, earn points and help others
