Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Cleaning in between oven door glass
How do i take it apart?
  • 2 more comments
  • handy_not Feb 22, 2008
    cleaned glass. got soapy water on inside of door w/out access. took the 4 screws off and now cant match the side holes to return to original. I want to remove inner door panel and wipe the other side of glass. I thought I'd have to lift door off hinges first, however it wouldn't lift, so I didn't want to force. What to do now?
  • rotnick Jan 14, 2009
    can't find manual on how to remove door to clean between glass.Also the probe light comes on randomly even when oven is off.This will be my last Kitchenaid purchase.
  • mbarrettboca May 11, 2010
    I have same Kitchenaid oven and my glass is dirty too. Between the glass panels. I'm now cleaning the oven and am reading that this may destroy the thermostat on the Kitchenaid. Do you know anything about how to dismantle the door to clean the glass, or whether the cleaning cycle will damage the oven? Thx.
  • handy_not May 11, 2010
    regarding cleaning glass in between....model is kitchen aid KEBC107KSS03.
    President:
  • 1,314 Answers
First its a whole lot of effort for very little return second there are two 100 pieces of glass in there and three it will just do it again but if you still want to reply with the brand and model number ill give you the procedure most of the time its backed on and leaves a stain even after cleaning
Posted on Jan 19, 2008
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
GE 1978 Slef Cleaning oven JKP26002wh 3 Layers of glass in door...How do I clean between the glass in the self cleaning aluminum window mechanism?
You will have to take the door apart to get to the glass that needs to be cleaned out. I would not recommend doing a self clean on an oven that is that old.
Dec 07, 2010 | GE JTP75CMCC Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Is it possible to clean between the two pieces of glass on the oven doors?
You would need to take the door apart, and even then the glass isn't really made to be taken apart. So it COULD be done, but it would be easier to buy new glass and replace it. It all depends on how much you want it to look clean.
Jun 10, 2009 | Frigidaire 30 in. Electric Double...
Need to clean the inside of glass on maytag's oven precision 500.
I have a GE range. The oven has a glass window. There are an inside and an outside glass. Somehow the inside of the two glases has gotten dirty. How can I clean this? Can I take the door apart? Thanks
Apr 25, 2009 | Ovens
Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
160 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
