Question about Mathsoft StudyWorks! Middle School Deluxe Math 5.0 (11543) for PC
How do i find the value of m when m=n over 5 - Mathsoft StudyWorks! Middle School Deluxe Math 5.0 (11543) for PC
  • 292 Answers
Do you mean
m=n/5 That is m=n divided by 5
Multiply both sides by 5
5m = n
which is the sme as n=5m
luciana44
Posted on Dec 09, 2009
Vlookup for duplicate cell values to display both names in separate cells
Check your formulae for a small error. Use F1 to guide you.
Jul 14, 2017 | The Computers & Internet
Calculate percentage increase
Percentage change = (new value -old value)/old value * 100%
If result is positive it is an increase. If it is negative it is a decrease
Here
%increase=(500-5)/5*100=9900 %
Dec 07, 2013 | Office Equipment & Supplies
Whats a median
The median of a finite list of numbers can be found by arranging all the observations from lowest value to highest value and picking the middle one (e.g., the median of {3, 5, 9} is 5). If there is an even number of observations, then there is no single middle value; the median is then usually defined to be the mean of the two middle values. It is similar to an average. or a root mean square value (RMS).
Nov 30, 2013 | Computers & Internet
Future value
When you buy it is worth $60, 000
I will assume that at the end of a year it is the whole new value of the house that is increased by 5%.
After 1 year value=60,000*(1+0.05)^1
After 2 years value=$60,000(1+0.05)*(1+0.05)=60,000*(1.05)^2
Do you see the pattern?
After 7 years, the value of the house will be 60,000*(1.05)^7
However if the increase is not compounded
Then after 1 year value=60,000*(1+0.05)
After 2 years, value=60,000*(1+0.05+0.05)=60,000*(1+2*0.05)
After 7 years, value=60,000*(1+7*0.05)
Depending on the coumpounding or not the two values will be different
With compounding: final value=$84,426.02
Without compunding: final value is $81, 000.
I showed you the possible mathematical solutions. It is now up to you to decide which is the one that applies to your case.
Jan 28, 2012 | HP 10bII Calculator
Why /5/=5 and /-5/=5?
Those are absolute value signs. Absolute value is defined as a number's distance from 0. So both 5 and -5 are a count of 5 away from 0 therefore the absolute value of both 5 and -5 would be 5.
I hope this helps! If this did help you, please give a thumbs up!
Jun 28, 2011 | Computers & Internet
@yahoo.comcreate a flowchart that will increase the value of the number by 5 if it is greater than 10 and display thae result. otherwise multiply the value by 5 and display the result
create a flowchart that will increase the value of the number by 5 if it is greater than 10 and display the result. otherwise multiply the value by 5 and display the result.
Jun 23, 2011 | Audio Players & Recorders
Determine if (5/6,-2) is a solution to -6x-7y=9
OK, you just have to put those values into the equation, do the math, and see if it works.
-6 * 5/6 - 7 * (-2) = 9 does it?
-5 - (-14) = -5 + 14 = 9 yes it does
You can (and probably should) always check a solution by testing this way. The definition of a solution is a value or set of values that cause the equation to work out. If the test had failed (say we had gotten -6 = 9 before, which is obviously wrong), we'd know that the values weren't a solution.
Jun 09, 2011 | Computers & Internet
-3/5x-8 what is the value of x when y=-11
The following solution shows how to find the value of x:
Start with the general equation given:
y = -(3/5)x - 8
Substitute the known value of y:
-11 = -(3/5)x - 8
Add 8 to both sides:
-11 + 8 = -(3/5)x - 8 + 8
-3 = -(3/5)x
Now multiply both sides by 5 to get rid of the denominator:
-3 * 5 = -(3/5)x * 5
-15 = -3x
Now divide by -3 to get x:
-15/3 = -3x/3
x = 5
The answer is x = 5.
Apr 27, 2011 | Texas Instruments TI-84 Plus Calculator
You save R20000.00 to invest for 5years. Interest is currently 10.5% and is to be calculated monthly. What is the future value of the investment?
2 0 0 0 0 +/- PV (present value, negative because you're paying it out)
5 *P/YR (5 years)
1 0 . 5 I/YR (interest rate)
FV (calculate future value, about 33,732)
Aug 09, 2010 | HP 10bII Calculator
I can't find how to graph absolute value function.
Here how you do it taking as exemples y1=x^3 -5 and y2=abs(x^3-5)
Turn calculator ON by pressing [AC/On] . Use arrows to select [Graph] icon and press [EXE]
On line Y1= enter X[^]3 -5 [EXE]
On line Y2= press [OPTN] [F5:NUM][F1:abs] [(] X [^]3 -5 [)] [EXE]
The graphs will be drawn one after the other. You might have to adjust the window limits.
Here is an ouput drawn on another calculator.
For negative values of the x-variable, Y1 has negative values, while in the same range, Y2 has positive values, equal and opposite to those of Y1. In that range, Y1 and Y2 are symetric of each other with respect to the X axis.
For positive values of the x-variable, Y1 and Y2 are identical.
Hope it helps
Jan 30, 2009 | Casio CFX-9850G Plus Calculator
Mathsoft StudyWorks! Middle School Deluxe Math 5.0 (11543) for PC Logo
Top Mathsoft Computers & Internet Experts
k24674
Bapco
Stitch85
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
