Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
How do I get video display off of my tv screen?
My amazon is not opening on the tv how can I fix it?
Basic Troubleshooting for Amazon Fire TV Try these common solutions to resolve issues like a blank screen, app errors, and problems with your display or audio.
Can't Connect to Wi-Fi for common solutions that may help.
Amazon Fire TV is Frozen, Blank, or Won't Power On for solutions.
Change Your 1-Click Settings. Manage Your Apps & Games.Contacting Your TV Manufacturer .
About 4K Ultra HD on Amazon Fire TV (2nd or 3rd Generation)Check the Video Resolution section under Display to make sure your connected TV meets HDCP 2.2 system requirements for watching video in 4K Ultra HD. For more information, go to Watching Video in 4K Ultra HD on Fire TV.
Calibrate Your Display
If part of your display is missing or cut off at the edges of your screen, your TV may be automatically scaling your picture.
You can use the Calibrate Display tool (Settings > Display & Sounds > Display > Calibrate Display) to adjust for this.
When you open the tool, you'll see four grey arrows pointing to the edges of your screen, which you can use as a guide when making your adjustments. Press the Up and Down keys on your Fire TV remote until the grey arrows are completely visible and touching the edges of your screen.
Contacting Your TV Manufacturer .Follow the on-screen instructions to make adjustments with your TV remote. You should still see the grey arrows from the Calibrate Display tool--make sure the tips of the arrows are completely visible and touching the edges of your screen.
Amazon Video Settings and Devices on the Amazon website.
Go to the Parental Controls section and enter a new 5-digit PIN under Amazon Video PIN. Then select Reset Your PIN.
MicroSD Storage for Amazon Fire TV (2nd Generation) .
USB Storage for Amazon Fire TV (1st Generation).If your storage device is compatible, try safely removing and then re-attaching it to your Amazon Fire TV:
  1. Select Settings > Device from the Fire TV menu, and then select your storage device.
  2. Select Eject.
  3. Wait for the on-screen confirmation before safely removing the device.
  4. Re-attach your storage device.
Oct 23, 2017 | Televison & Video
Hi I have a l32wd12 r a TV and it will not turn on
If the clock is on then the unit is receiving power; maybe the external input feature (which tells the TV which outside source to display on the screen, e.g. cable TV, DVD player, VCR player, etc.) is not set to display the TV channels. On my Sony TV there is a button that displays TV setting options (e.g., Favorites, TV List, External inputs and settings). The external inputs function displays the options as video 1, video 2, etc., right up to video 6. My video 3 is for the VCR, video 4 is for the DVD, and video 5 is for the cable TV channels. If the TV is set for say video 3 and nothing is playing on the VCR, the screen will be dark (almost as though the TV is off). Your solution might be as simple as choosing the right external (video) input for the TV to receive the channel signals.
Sep 19, 2014 | Televison & Video
S-video out to tv nvidia 9300 gforce won't work
obvious things first. have you tried the other input plugs on the TV? do you get the same problem with plugs 1 and 2?
you can try only having the TV connected to the Graphics card and turning on the PC see if it comes up as the primary display automatically.
have you tried configuring the Nvidia setting so ONLY the tv is a display instead of dual monitor?
doing these will rule out faulty cable or faulty S-video plug or Faulty TV input plug.
Dec 07, 2012 | Nvidia 64MB GeForce3 AGP Video Card with...
Our son pushed some buttons, and now we cannot get rid of the square in the upper right corner that says "video 2". HELP!
Video-2 is on-screen display. Press Display/ info button on tv remote, on-screen display will disappear.
Please note that only Sony tv remote will work to cancel on-screen display.
Thanks.
Jul 28, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Why can't I get any video when I connect the S-video output from ny laptop to the S-video input jack on my TV?
Not only must you connect the two physically with the S-video cable, but also divert the laptop screen display to the TV or replicate the laptop screen display on the TV screen.
On Toshiba laptops, you use the Fn-F5 key combination to play with the display. Look at the screen capture from my Toshiba laptop. While pressing simultaneously on the Fn and F5 keys, use the right arrow to cycle through the various schemes. For your case use the 4th or 5th scheme.
Jul 27, 2010 | Toshiba Satellite M115-S3094 Notebook
On screen display menu
Hi and welcome to FixYa,
Almost always, there would be a yellow RCA female jack at the rear of the receiver that is marked "VIDEO OUT". With an RCA to RCA cable, connect this VIDEO OUT to a composite "VIDEO IN" of the TV. The TV must then be set to display AUX / LINE / VIDEO 1 / AV.
Good luck and thank you for using FixYa.
May 28, 2009 | Denon AVR-4800 Receiver
The Video display stays on the TV
If it is Sony TV then press " i " or Display button on TV remote and on-screen display will disappear.
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bose Remote Control RTC1T-27
I called Firedog and paid them $80 to come out and fix it.
Jan 04, 2009 | Bose Lifestyle 20 System
Movie Files will not display on the TV.
Its quite possible your laptop has lost its association with your TV as a "secondy monitor".
To check this, minimise everything and right click on the desktop and go to Properties. Then navigate to the settings tab. This will show you how many displays it considers itself to have.
Click on number 2 (if visable) and click on extend my windows desktop to this monitor.
You should now be able to go between screens
Apr 22, 2008 | Toshiba Satellite A105 Notebook
"VIDEO 3" ON SCREEN
It is normal for VIDEO 3 to be displayed in the upper left of the picture if there is no signal present at the INPUT 3 jacks. This is to let you know that although the picture is black and there is no sound, the TV is still on. If you have a good signal at INPUT 3 and the VIDEO 3 stays on the screen, take the Sony remote, point it at the TV and press the DISPLAY button until you see "DISPLAY OFF" on the screen. About 3 seconds later, the words should vanish.
Aug 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
385 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
