Question about Opticon Computers & Internet
Opticon H19 will not power on.
Even with a new battery installed, my H19B will not power up. If I plug the USB cable in (the only way I have of charging the PDA), the right-hand red light comes on (after about 3 minutes of waiting) but the battery does not seem to be charging and the screen remains dark (even after leaving it 'charging' over night).
zzedly
  • 300 Answers
SOURCE: Dell Latitude C510/610 wont turn on
I have more of a suspicion of the CPU fan than the hard drive, right now. If a hard drive goes bad, the system will wake up, go through it's POST (Power On Self Test), and then tell you there's an issue with the hard drive. If the CPU fan goes bad, the system turns on, sees an RPM of 0 on the fan, then turns back off. That hypothesis also fits in with the slowness you were seeing. If a CPU starts to overheat (because the fan isn't running well), it will start to throttle the clock speed down in an attempt to produce less heat.
Unfortunately, it sounds like your laptop may be in need of a professional repair facility.
Posted on Mar 07, 2008
SOURCE: Nikon D40 Image Darkness
turns out that the camera is faulty and I've sent it for repairs to get a new part
Posted on Apr 02, 2008
POSresource
  • 3 Answers
SOURCE: I cannot get my opticon barcode reader to work
Hi!
Keyboard Wedge Barcode Scanners are sometimes tricky because they will not operate if the keyboard is physically attached to the Scanners' "Y" cable. A possible solution would be to attach an additional keyboard to the "Y" cable and simply set it aside un-used. (This would allow you to continue to use the Wireless Keyboard; which I assume is USB). I may also be able to program the scanner to operate in a Laptop Mode which would allow you to operate successfully as-is. I would need your exact model number to investigate if this is possible.
Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Posted on Apr 04, 2009
  • 244 Answers
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
Posted on Jan 03, 2010
  • 18 Answers
SOURCE: please wait very low battery
This is, clearly, a battery issue. Try restoring the iPod by following this article "http://support.apple.com/kb/HT1339". If your issue persists, then you might have to send the iPod in. It might cost you, if your iPod isn't within warranty.
Posted on Jan 07, 2010
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
How to open APC UPB10 battery pack to change the chargeable battery?
1. Remove front cover by sliding front panel down.
2. Install 4 new AAA (LR03) batteries (sold separately) and replace cover.
3. Turn unit on by sliding ON/OFF switch towards USB port. LED will
illuminate.
4. Plug USB charging cable (sold separately) into the Emergency Power Pack's USB port.
5. Plug the other end into your mobile device. (Make sure you do this last, as a few devices will not recognize the charge otherwise). Your device is now being charged
Apr 27, 2014 | Computers & Internet
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Windows 7 cannot detecct my OPN-2001
It seems that this only has drivers for Windows XP, but you can try installing the XP drivers on windows 7.
http://old.opticon.com/uploads/Software/USB%20Drivers%20Installer.exe
Here is the link to download the drivers, make sure the scanner is not plugged in until after the drivers are installed. This may not work, but i have had to do this with other hardware and sometimes it does work.
Feb 28, 2011 | Opticon OPN 2001 Mobile Data Collector...
Have new drive Hitachi SimpleDrive Mini 250GB USB 2.0 Portable External Hard Drive SDM/250RW (Red Wine) and works fine on Dell precision M4300 laptop Vista OS with either one or two usb plugs (so no extra...
Most USB hard drives require an external (or secondary) power cable to power the devices when connected to laptop or netbook computers. In some cases, even older desktop computer models will require a similar cable.
This is due to the specifications for the USB standard as it dictates the amount of voltage that a USB port can deliver. Some USB ports are considered "powered" and are sometimes identified by the USB logo and a small "+" sign to indicate the added voltage.
Note: Not all manufacturers use this logo, so if your computer doesn't have this variation of the logo, it doesn't necessarily mean the USB port is not powered.
This added voltage supplies additional current to power smaller devices, such as portable (or 2.5") USB hard drives. However, in the even that the USB port is not powered, then only the minimum amount of current is supplied. This should be enough to slightly power the drive, but not sustain it, thus causing the clicking noise and there isn't enough current running through to move the arm that reads the data on the hard drive.
Chances are that the USB ports on your Asus Eee are not powered and won't allow your hard drive to run until either a secondary cable is purchased or if you use a powered USB hub instead.
The secondary cable looks a lot like a Y-USB cable with one end that connects to your hard drive and the other end consisting of 2 USB plugs that both connect to existing USB ports on your netbook. Between the 2 USB ports, they can draw enough current to power the hard drive - the downside being that if you only have 1 USB port you cannot utilize the cable or if you have 2, they will both be occupying the ports while the hard drive is in use. These cables can cost about $1-7 depending on brand and can be found online in retailers such as eBay & CompUSA.
The USB powered Hub is a more expensive solution, ranging at about $10-25, but is the higher recommended of the 2 solutions since it will provide its own power supply to the tiny device, will use on 1 of your USB ports and since it's a hub, they usually have anywhere from 3-5 additional USB ports (all powered) for you to use, if needed. Some even include built-in memory card readers and they do not require any additional drivers or software to install and can work on any desktop/laptop/netbook.
Aug 14, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Opticon OPR-3201-USB computer does not recognize scanner.
get your manual and scan in the appropriate "host" option. You will have to scan in the "USB host" barcode. There may be more than one. Your scanner should be set to the HID usb Keyboard option. Or contact the Opticon Help Desk. You can download the manual at http://office.manualsonline.com/manuals/mfg/opticon/opticon_scanner_product_list.html
Oct 30, 2009 | Opticon LGE1105RHHS-000 Handheld
Computer not recognizing usb connected nav device
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jun 05, 2009 | Magellan Maestro 3200 GPS
Dead batteries when fully charged
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Jun 28, 2008 | Fuji FinePix S7000 Digital Camera
Can we make new charge for SAMSUNG K3?
You can easily get usb powerplugs for a few pounds from high street electrical shops or online retailers. It costs a few pounds. Why I even buy really cheap mp3 players on ebay for about £14 and they come with the usb power plug. The powerplugs are more useful than the players :)
Oct 26, 2007 | Samsung YP-K3 MP3 Player
Computers & Internet Logo
129 people viewed this question
Top Opticon Computers & Internet Experts
David Payne
David Payne
Are you an Opticon Computer and Internet Expert? Answer questions, earn points and help others
