I have a Sitecom WL322 (300N Wireless ADSL modem ) router. I can connect unsecured Ok, but no connections successful yet with TKIP or AES encryption. Suggestions?
  • thedunning Dec 10, 2009
    thanks but no WEP connection possible either. have reset router and DHCP settings too.
  • 6,487 Answers
If the wireless not working with WPA TKIP or AES you can try enabling WEP aas the wireless security for your network and lets see if that will be working with that level of security....
Posted on Dec 10, 2009
  • Mark Gil
    Mark Gil Dec 10, 2009
    You can also try doing firmware upgrade on your router and also a driver update will be a good thing to do because sometimes old driver for wifi card dont work well with WPA......
Try to change somethink like... wireless settings
Banda : bandVal = 5; bandVal = bandVal-1; var bandTbl = new Array("2.4 GHz (B)","2.4 GHz (N)","2.4 GHz (B+G)", "2.4 GHz (G)", "2.4 GHz (B+G+N)"); for (i=0; i'+bandTbl[i]+''); else document.write(''+bandTbl[i]+''); } 2.4 GHz (B) 2.4 GHz (N) 2.4 GHz (B+G) 2.4 GHz (G) 2.4 GHz (B+G+N) ESSID : document.write(showText(50))Canale : regDomain = 3 defaultChan = 13; var domainMin = new Array("1","1","1","10","10","1"); var domainMax = new Array("11","11","13","11","13","14"); for (i=1; i'+j+''); else document.write(''+j+''); } } } 1 2 3 4 5 6 7 8 9 10 11 12 13 document.write(showText(54))Client associati : document.write('') document.write(showText(85))Analisi del sito : document.write('') document.write((showText(606)))Channel Bandwidth 20/40MHz 20MHz var iDOD = 1-1; document.wlanSetup.wlanNChanWidth.selectedIndex = iDOD; document.write((showText(607)))Extension Channel 9 Root AP SSID : "> document.write(showText(58))Indirizzo MAC 1 : document.write(showText(58))Indirizzo MAC 2 : document.write(showText(58))Indirizzo MAC 3 : document.write(showText(58))Indirizzo MAC 4 : document.write(showText(89))Imposta sicurezza : document.write(showText(89))Imposta sicurezza : document.write(showText(89))Imposta sicurezza : displayObj(); if(wisp==1) document.wlanSetup.chan.disabled=true;
Posted on Jan 25, 2010
SOURCE:
Intallations troubleshooting for modem
try opening the connection (remove the encryption) and see if will connect. chances are it will, but if it doesn't and other devices are connected the wifi, the tv is defective.
so it connects without any encryption (wifi password) but were not done. we want to find the encryption method that will suit. start with wpa2 aes, and if it doesn't yet connect, then wpa2 tkip. then with the older wpa standard. first aes, and then tkip. if that doesn't do it let me know what model of router you have
May 19, 2014 | Computers & Internet
Can't connect to wifi
Try turning off all encryption in the wireless router, delete the SSID's wireless profile in your computer, then connect to the SSID with no encryption. Windows should warn you there is no encryption, and it may limit your connection speed to 54Mbps (802.11n requires WPA2/AES encryption).
But if it then connects OK like that, you know the problem is/was an encryption mismatch.
In that case, switch the wireless router back to WPA2-Personal or WPA2-PSK with AES encryption, delete the newly-created wireless profile for your wireless router's SSID in your computer again, and connect to your WiFi with encryption, being careful to enter the WPA2 passphrase (8 to 63 characters) correctly when prompted.
Feb 11, 2014 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Have a Linksys Wireless router Model WRT160N Security is set at WPA2 Personal i can not get my new iPAD to connect when i diasable Security it connects I am looking for a suggestion I also need...
@joea1956
Try the following:
1. If you want WPA2 encryption on your router, (which also have higher security and compatibility issues with wireless cards), you could try WPA2-TKIP (which is standard encryption and made compatible for all wireless cards) or WPA2-AES (for specific wireless cards that are unable to connect to TKIP encryption)
2. If Step 1 won't work, try to lower your security encryption to WPA-PSK (either TKIP or AES) and try again. If this works, your IPAD2's wireless card doesn't support WPA2 encryption yet.
If all of the above fails, I do not recommend WEP since it's easily cracked (for advanced users) but you could try it as a last resort.
Good luck.
Sep 08, 2011 | Linksys WRT160N Wireless Router
I would like to put a password on my moden but how plz tell?
Hello and welcome to FixYa;
connect to the buffalo router via an ethernet cable.. then.
click this link
192.168.11.1
(if link isn't working, copy and paste 192.168.11.1 in a new tab in your browser)
Basic Settings
Wireless
Wireless Encryption (WEP/TKIP/AES)
select TKIP or AES. or you can
Hit Advanced button at top right of HOME page.
Wireless Config > 802.11g,
under Wireless Encryption choose TKIP or AES,
you can input your WPA-PSK (Previously Shared Key)
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 31, 2011 | Buffalo Technology WHR-G54S Wireless...
How can i change set up from TKIP to AES
This model does not appear to support AES, so you won't be able to change it.
Feb 28, 2011 | Microsoft Broadband Networking MN-700...
In network settings for bd c6500 it says "due to change of a wifi policy , cannot support the tkip security type in 802.11n mode." What does this mean.
The Wi-Fi Alliance has a timetable for eliminating outdated WEP and TKIP security from certified Wi-Fi devices: The Wi-Fi Alliance is eliminating older encryption methods from the certification process for new hardware.
TKIP and WEP won't be allowed in new devices with the Wi-Fi stamp in a staged elimination over three years starting in 2011.
Anyone reading this should be well aware that WEP (Wired Equivalent Privacy), the original local-link encryption standard in 802.11b, has been broken since 2001, and horribly so since 2003.
TKIP (Temporal Key Integrity Protocol) was a backwards compatible replacement introduced in 2003, and intended to work with older silicon that didn't have either the circuits or computing ability to handle WEP's real replacement, AES-CCMP ( AES-Counter Mode CBC-MAC Protocol). AES (also from 2003) is often called WPA2 encryption, although it's more particularly an encryption type that's part of WPA2.
In a nutshell, they're doing away with WEP and TKIP
The 802.11n standard only allows the use of AES keys.So you'll probably have to connect at 802.11b, or g speeds and settings. Might try to Right click on your Wireless Network Connection and select Properties.
Select Wireless Networks Tab
Enable the checkbox "Use Windows to configure my wireless network settings"
Click OK
Doesn't seem to bode well for XP users for the moment.
Hope this helps you.
Good luck
Hope this helps you
Nov 27, 2010 | Computers & Internet
Pls help me to set a password on my Wifi, thanks
From the HOME page (192.168.11.1),
Basic Settings > Wireless > Wireless Encryption (WEP/TKIP/AES), select TKIP or AES. - or - Hit Advanced button at top right of HOME page.
Wireless Config > 802.11g, under Wireless Encryption choose TKIP or AES, you can input your WPA-PSK (Previously Shared Key) Use 20 Character Key!
Use a minimum 20 character WPA Key.
For further clarifications, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 10, 2010 | Buffalo Technology WHR-G54S Wireless...
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Router greatly slows up/downloads to 25% of direct from modem
I am using a Belkin N1 Vision router with Vonage and i am having no issues with speed at the moment. What OS and connection are you using. If its Vista and Wireless make sure you are using AES encryption and not TKIP as my wireless network was painfully slow using TKIP and lightning with AES and WPA2
May 11, 2009 | Computers & Internet
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
783 people viewed this question
Alun Cox
k24674
