Question about Grilling
Grill ignites (LPG)but the the rear burners don't appear to be lit
    Problem Solver:
  • 6 Answers
Low gas flow to rear probably due to spider webs in venturi's and/or burners..
Posted on Jan 21, 2010
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
Doesn't seem to be enough gas going into the
Hi am welcome to FixYa. I am Kelly.
1. Does the LPG tank have gas in it?
2. Is it one gas control or more that gives you this symptom? If it is more than one and there is gas in the LPG tank then the LPG regulator can be the problem.
3. There can be debris on the face of the gas orifice where the burner mates to to the gas control selector assy. (Spider webs / grease /dirt)
4. The air hole in the burner can be partially blocked with something (same as above Grease, dirt, cob webs)
5. The holes in the burner itself can be corroded or blocked with something. (This one would be pretty obvious)
6. The gas valve 'heat control may not be functioning properly.
7. There is a very remote possibility that the LPG hose has collapsed.
I would check the orifice and the burner holes for obstructions after verifying the LPG tank is usable. Then the next suspect would be the LPG regulator.
Thanks for using FixYa,
Kelly
Apr 07, 2010 | Weber Genesis Silver C Grill
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
My grill does not exceed 300 degrees. The rear burner is barely lit, it sputters with a blue flame. The Front and middle burners run well, blue flame no yellow. I changed the regulator with one from home...
Bypass valve need reset. All grills made after 1996 have this valve.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait 90 seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and a rep walk me through it.
Jul 08, 2009 | Weber Genesis E-310 Gas Grill
Jenn Air gas grill with cast iron burners...only ignite on one side of burner...other side ports will not ignite...but will ignite right away with lit match...all three burners do this...
It sounds like your cross-over **** located underneath on the back of the burner is needs cleaning. Take your burner out, turn them over and your will see a slot on the rear of the burner. wire brush the slot until it has a clean ****. This cross-over **** is what brings the flame to the right side.
Apr 19, 2009 | Grilling
Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Jun 17, 2008 | Weber Genesis Gold B Grill
Char Broil Commercial Series
What you are expierencing is a restriction in either the line coming from the regulator or a bad regulator. Most likely I would lean towards the regulator.
Jun 11, 2008 | Grilling
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
