Question about Sony Playstation 3 (PS3) Console
My Playstation keeps saying hard disks file corruplted and when i click okay to fix it it gets to 100 % and turns its self off and then back on and then tells me to do the same thing
  • daltonsowah Dec 10, 2009
    i cant as soon as the ps3 turns on it straight away comes up with the hard disk drive corrupted
  • 31 Answers
Connect it to the internet then do it
Posted on Dec 10, 2009
SOURCE:
Playstation 3 (PS3) Console: Playstation 3 is saying that the hard disk file sy...
Guest
If you are getting the corrupted hard drive message the link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or queestions
Issken
http://www.fixya.com/users/issken
May 17, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
Hard disks file is corrupted
Has it asked you to reformat the hard disc? If you have tried that and it still doesn't work then you may need a new hard drive. Don't worry, for $20-$50 (US) you should be able to fix it. Without knowing what happened before that it's hard to say. But my best guess is that the hard drive is internally damaged in some way. Just take off the small panel on the left side, remove the screw, use the little handle and gently pull to the right then out. It should be a Seagate SATA hard drive 20, 40, 60, or 80GB. Just buy a new one from your local store or online. Make sure that you mark the bad one before you get the new one near it so you don't get tem mixed up. Then remove the 4 little screws on the mountinng cage, switch hard drives, install back into PS3 and it will give you the format screen again. Click yes and it will format, turn off, back on, and you should be all set!!
May 04, 2010 | Sony Playstation 3 (PS3) Console
Error message that says the hard disk's file system is corrupted
tlatrice_66
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
Let me know if you have any more problems or questions
Issken
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
The Hard Disk's file system is corrupted and will be restored
apart from physically reformating the hard drive yourself (taking it out and loading it on laptop or desktop and format, at your own risk), there isn't much else you can do. If the console is still guaranteed then contact sony and they will send you a new one.
If you do format it your self when you replace it in your ps3 you will need to format it again using thier options.
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
THE HARD DISK'S FILE SYSTEM IS CORRUPTED AND WILL BE RESTORED
hold in the power button until you hear 2 beeps. might not work the first time. if no 2 beeps repeat power button again or until 2 beeps. go to restore hard disc and click on it. you will lose anything saved on the hard disc but fixes it 75% of the time. did it myself this morning.
by a new hard disk it is easy. The only thing is that you will LOSE  EVEYTHING THAT YOU HAVE ON THERE! you can find a cheap one for like 80 bucks I have a 160 gig in now and i paid 89.50 email me if you have questions baldwinkk@gmail.com
May 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
