Question about Sanyo Xacti VPC-S770 Digital Camera
I have a 7.1 mega pixel camera and the lens will not retrack please help
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 09, 2009
How much pixel picture view in PC1043 canon
Canon Poweshot A70 Pc1043 features 3.2 Mega Pixels, a 3x optical zoom lens, and a color display screen.
Hope, this is what you are looking for.
Regards
Sunny.
P.S: If your problem is solved, please do accept the solution.
Jan 10, 2011 | Canon PowerShot A70 Digital Camera
MyNikon 6 mega pixels camera lens is not closing fully
lens unit is unable to go back,mechanism is defectivebecauz of gearbox,guide/guide-pins lacks fullrange of movement,so give it for CLA.
Mar 08, 2010 | Cameras
Will not display picture on i inch screen
The problem was the lens slide cover. It was making the required connection when slided the open the lens. It was intermitted. So I purchased a new camera for $79 bucks!
I went from a 3.3 mega pixel to 10 mega pixel.
Thanks for your help!
Jul 30, 2009 | Vivitar ViviCam 3705 Digital Camera
My lens wont retract and camera wont go on....
There is probably severe internal damage to the camera.
Apr 09, 2009 | Casio Cameras
Suggest the best brand in digital camers in 8-10 mega pixels
For the money, I think the Nikon Coolpix P60 is the best bang for your buck. I bought one myselft in August 2008 and dropped it in Feb 2009 so I must by a new camera - i am buying another P60 !
Jan 22, 2009 | Nikon COOLPIX P60 Digital Camera
Lens plastic cover little sheets wont open.
I need to remove front cover and look for an obstruction or possible substance spilled or splashed in camera. N/C for estimates! www.flcamerarepair.com Art Schneider (40 years exp.)
Mar 31, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
From june wood
i have a mercury classic cam 1.3 mega pixels and lost my disk could u please send me the drivers for my camera as i cant get my pics off the camera ty i need software digital camera mercury 3.1 mega pixel model vq2220 maximum resolution
Nov 17, 2007 | Kobian Mercury 3.1 Deluxe Classic Digital...
Sanyo Xacti VPC-S770 Digital Camera Logo
73 people viewed this question
Top Sanyo Cameras Experts
Tony
teddyboy
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
