Question about Roper REX4634KQ Electric Dryer
My REX4834KQ dryer will start, but doesn't get hot. It also will not turn off automatically anymore!
    Sergeant:
    Champion:
  • 289 Answers
First make sure you have 220 going to your dryer.in alto cycles the timer will not work if the heating element is not working.next you nead to remove the back panal and the power cord cover.if you look to the right you will see the heater housing.at the bottom you will see two wires going to the heating element.remove the wires.with a meter check the element to see if it is open.if it is than the element is bad.part#3403585 if not than we nead to move up.check the next high limit switch to see if it is open.if it is than it is bad.next we nead to go higher to the hi-limit tgermostat at the top of the heater housing part#3977393. if it is open than you nead to replace it.
Posted on Dec 29, 2009
Dryer hot at first and then stay cold
Sounds like the thermocouple needs replaced. When ever the couple doesn't make enough electricity the gas valve is shut down automatically. Sounds like your thermocouple is right at the threshold of minimum voltage and doesn't generate enough voltage to keep valve open.
If not that try YouTube for some good diagnostic videos:
https://www.youtube.com/results?search_query=Whirlpool+gas+dryer+pilot+light+goes+out+quickly+or+doesn%27t+stay+on
Oct 28, 2015 | Whirlpool Dryers
My drum doesn't turn anymore after I have used the basket. It now does a loud humming sound.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Miele T9800 Electric Dryer
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
heatman101
Aug 09, 2011 | Hotpoint Dryers
When i tried to turn on the dryer, i get a humming / buzzing sound and the drum / motor doesn't spin anymore
heatman101
Aug 07, 2011 | GE DWSR463EG Electric Dryer
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Aug 07, 2011 | GE Dryers
I have a Whirlpool WED 7300 Dryer and it keeps beeping during drying, Help
I had the simmilar problem when I heat load of sheets, I guess maybe it is because it is getting too hot inside the dryer, so I set the cycle to manual and adjust the temp. to low, it doesn't beep anymore. hope it helps.
Aug 03, 2010 | Dryers
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Roper REX4634KQ Electric Dryer Logo
186 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
