Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer will not print because it states that an ink cartridge is empty. However, it will not recognize a new HP ink cartridge. I have followed the recommended reset procedures. The printer display screend shows the correct data on the new cartridge, but when I attempt to print, the response is the light cyan ink cartridge must be replaced. This is a repeat problem.
I have the same problem and have replaced the cyan cartridge twice to no avail.
Posted on Dec 14, 2009
Could be a bad cartridge
Posted on Dec 10, 2009
I removed cartridge to check for ink smears, then replaced it. Now it won't print.
never take a cartridge out,now it doesnt recognize it,get a new cartridge,or call hp
Jul 14, 2015 | HP Deskjet 2512 All-in-One Printer
Windows 7 doesn't recogize new ink cartridge on HP C6280
I would go to HP and update the C6280 printers drivers. It sounds like there is an issue with the driver. It there is not an update then I would uninstall the driver and reinstall.
Jan 19, 2013 | Dell Inspiron Core i7 640GB HDD
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
HP 8250 Cannot Print - Printer Senses New Ink Cartridge as EMPTY
you need to have authentic hp cartridges,if you bought cheaper,it will not work.
Apr 23, 2017 | HP Photosmart 8250 InkJet Printer
Printer does not recognize new ink cartridge
Are you using "refilled" hp cartridges? If so, they may be interpreted as "empty" or a non-hp cartridge if the carrtidge shell was manufactured prior to the recent time that hp began coding the electrics on the same type cartridges. This can also happen if you are using "compatibles". If this is the case, try buying original new hp carts. If that is what you already have, return the cart to the store as defective and as for a replacement.
Apr 28, 2010 | HP Photosmart 3210 Printer
My refilled canon ip1600 ink jets are reading as empty
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Jun 09, 2009 | Canon PIXMA iP1600 Printer
Hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Feb 09, 2009 | HP Photosmart C7180 All-In-One InkJet...
Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Jun 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
441 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
