Question about Mitsubishi WT-46809 46" Rear Projection Television
The picture bows out toward that edges, with the colors skewed. If is hit the side of the TV, it fixes itself for a short time.
  • mbosy Aug 30, 2010
    Instructions for replacing convergence chips in WT-46809
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If it is a WT-46809 it uses two of the STK-392-570 CONVERGENCE CHIPS.
I have repaired a lot of these sets and they often develop internal bad connections---most of the time resoldering them will not help--both chips have about 18 pins and what I have seen (dozens of times) the pins break loose inside the chips.
Considering the time and trouble just to get at them and the fact you can buy a pair of the chips on Ebay for about 14 dollars plus shipping I just replace them and problem is gone.
I have start to finish, step by step instructions for this repair in this set--tell you everything you will need and how to do the repair.. I am going to post a photo so you can see what the chips look like.
If you want the instructions let me know and I will post them here for you for free.
If this has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 09, 2009
  • 1 more comment
  • SD Tech
    SD Tech Dec 09, 2009
    Here is what the chips look like.
  • Steve Carcaterra Sep 23, 2010
    please post instructions for fixing mitsubishi wt-46809 convergence problems
  • SD Tech
    SD Tech Sep 23, 2010
    If you want instructions post either a question in the free section Attention SD TECH OR THE paid section--as little as 6 dollars there.
    I do not follow up on requests for help in this way.
    SD TECH
TV no sound, picture bleached and skewed
model. serial numbers would be helpful.
Apr 19, 2014 | Televison & Video
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Bowing of picture at top and bottom towards center.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Hitachi projection tv model 3 51gwx208
Do you mean that at the top of the picture, the red color has shifted downward, bowed towards the center? If that is what you see, one color suddenly bows toward the center on any side of the picture, then it means that one of your convergence IC's has burned out and needs to be replaced. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned the convergence circuits in a projection TV then allow a qualified tech to handle it for you.
Aug 05, 2007 | Hitachi 51GWX20B 51" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
169 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
