Question about Cell Phones
Hi i have a sharp gx30i and it says on the screen error in sim -mep any idea how i can fix please
Steps in unlocking 912SH
Hi if you want to unlock your sharp 912sh mobile from network lock .Then visit Superunlockcodes.com here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile .They also provider step by step instruction about how to unlock mobile .They are
1 - Switch ON your Sharp 912SH with an ACCEPTED SIM Card.
2 - From front screen type *01763*6371#.
3 - The Sharp 912SH will reset back to the main screen.
4 - Press M button.
5 - Scroll to Settings and press SELECT.
6 - Scroll to Security and press SELECT.
7 - Scroll to MEP locks and press SELECT.
8 - Enter your phone's Code and press OK.(the default code is 0000)
9 - Scroll to Network and press SELECT.
10 - Scroll to Deactivate and press SELECT.
11 - Enter the Unlock Code and press OK.
12 - The Sharp 912SH should then display DONE and be unlocked.
Nov 20, 2012 | Cell Phones
Please help me to open mep code for zong sim for my blackbery 8900
Hi to get MEP code visit Simpleunlocking.com here they ask you the IMEI number of your Blackberry 8900 mobile .Then they deliver you code to unlock your Blackberry mobile from zong network .
Nov 13, 2012 | RIM Blackberry Curve 8900 Smartphone
Hey can you please unlock bb curve 8520 ...imei:357257.04.904092.1
Hi, You can get the unlock code for a Blackberry Curve 8520 from http://www.unlocking4u.com/blackberry-8520-curve/rs6wp9/ at affordable cost.
Here are the steps for unlocking a BB Curve 8520,
1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry 8520 Curve will now be unlocked.
Sep 20, 2012 | RIM BlackBerry Curve 8520 Smartphone
Just came back from mexico and i need the MEP code to my Blackberry Curve 8520 from Movistar so I can use my AT&T Sim card
To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use it with adifferent phone provider, Please click on this link and follow my instructions:- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB site also - UnlockFree http://www.unlock-free.com
Nov 01, 2010 | Cell Phones
I need my mep code for my blackberry curve 8520 imei 359428031689888 please really need to get it sorted ??
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your Blackberry 8520.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
Oct 15, 2010 | RIM Blackberry Curve 8520
I'm trying to unlock my BB storm 9530,after I type "MEPPD" I enter "MEP2" or "MEPP2" but still I dont get any window to put the unlock code in,any ideas ?!
Before you start, you MUST have an Unauthorized Sim Card inserted. An unauthorized Sim Card is a Sim Card that is NOT belong to the provider of the phone. Example: If you have a Verizon phone, you need to insert a T-Mobile Sim Card inside the phone before turn it on. 1. Power on the phone.
2. Phone will said "MEP check failed. Do you want to enter MEP unlock code". Select Yes.
3. "Enter Network MEP code (# left)". Enter the unlock code.
4. Press Enter, you should see “Code Accepted”
5. You need to check Network Connection is set on GSM/UMTS. Menu>Manage Connection>Mobile Network Options and make sure it GSM/UMTS.
6. Once GSM/UMTS is selected. You can now ready to make phone call.
Notice: If the network not working after your phone is fully charged and unlocking process “Code Accepted”. You must change from Verizon CDMA network to GSM Global Network a few times, after change from Verizon CDMA to GSM Global 3 times is completed, leaves it on GSM Global Network. Now it should work. (Verizon 8830 World Edition DOES NOT work in USA)
Mar 29, 2010 | RIM BlackBerry Storm 9530 Smartphone
Network MEP code
the network code will be at the home or office on the wireless network roter
please rate my help
thank you
Apr 20, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
