Question about Sony Handycam DCR-SR62 Camcorder
Picture rolls on screen on start up. - Sony Handycam DCR-SR62 Camcorder
I have the same problem ,can't get an answer unless you pay and no guarantee it will work
Posted on Apr 05, 2010
SOURCE:
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Once it's turned on, the screen (picture) starts
Bad LCD controller, see sample here (notes, I remove the cover LCD controller cover to show the board): http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
There are more than one version of the board, you need to match it with the LCD panel number:
http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Aug 19, 2009 | Westinghouse LTV-32w3 HD Television
Mitsubishi TV picture rolling
Look on the back and see if you have an adjuster.(It should say
H-HOLD) Just turn it very slowly until the picture stops rolling,You can do this by watching the tv screen in a mirror.
Please rate this solution.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Magnavox tv
I think I'm having the same problem dont knowif its the cale or the TV I have an old one too,gets wavy kinda rolls vertically
Jul 05, 2008 | Philips Magnavox 27MS343S 27" TV
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Display screen is rolling
a few possibilities =
lcd damaged
main board damaged
or loose connection.
any of the three needs to be repaired.
sorry for the bad new :(
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Sony Handycam  DCR-SR62 Camcorder Logo
208 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
