Question about Dewalt 1/2 Drill DW236
How do I remove the old chuck from my keyless drill?
  • 244 Answers
Hi \
Try opening the chuck all the way....there should be a screw/nut at the back that you can get a tool on>
HTH,
Mike...
Posted on Dec 10, 2009
Replace Keyed Chucks with Keyless Chucks
Can't help with this other than suggest that you do not proceed, Keyless chucks can be problematic particularly if dust /debris from material being drilled finds its way into the chuck..
Mar 30, 2017 | Drills
Require a 10mm and a 13mm Male-fitting Keyless Chucks
I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
Apr 04, 2017 | Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Keyless Chuck releases bit when reversed
hi
open the chuck all the way and then look down in the centre of the chuck you should see a cross head screw
unscrew and the chuck should pull out as this is on a taper system ( note the screw is left hand thread )
Nov 21, 2017 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 1/2 Drill DW236 Logo
290 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
