Expert
- Posted on Dec 09, 2009
Re: I have a propane furance in a mobile home. When I...
If you are getting power to the gas valve, then all of the safety switches should be closed. if you have any drain lines off of the inducer fan and at the bottom of the heat exchanger, make sure they have a trap and have water in them. the pressure switch may be the culprit.
If I turn the thermostat down and back up a couple times the burner will light and it will run another cycle.
