Question about Denon AVR-1801 Receiver
I have a problem with my volume control. I was playing a disc when suddenly the volume increased violently and I had to turn the system off. When I turned it back on my volume control will not go beyond '10' which is too loud for playback. The usual volume I listen too is about '30' or so depending on how old the recording is. I have tried resting the system and allowing it to cool however the problem persists. Could you please help.
  • stevehop Dec 09, 2009
    Thankyou for your assistance. My volume control button does turn but the volume does not progress beyond '10'. It does go lower to lesser volumes. The volume control responds to my remote but also does not progress beyond '10' the same as my volume button. The display on my receiver I have noted shows 'ANALOG'. Is this significant?
  • 244 Answers
Ok first, try disconnecting the power source and everything connected to the unit and let it sit for fifteen minutes. This should perform a soft reset...if you have HDMI connections that could be a problem as well. By disconnecting all connections to the unit this problem could be inadvertently cured as well.
Second, take the top off the unit and use a very good magnigying glass; check to see if you have any obviously damaged electronic components...the damage should be obvious to even the untrained eye.
If the unit is still under warranty, consider returning to manufacturer for repair: http://www.usa.denon.com/ServiceCenterLocator.asp
HTH,
Mike...
Posted on Dec 10, 2009
  • 3,741 Answers
This happens if the button of volume getting loose or getting stuck up and not spinning properly.so check out if the button is easily spinning and actually functioning to increase or decrease the volume when you spin the button.many times the internal connection of the button becomes loose so it only works for some extent but does not work properly. and the other problem is the internal hardware problem in the board.as you mentioned that suddenly the volume got increased without doing anything.so it can be short circuit in the circuit board.its not a major problem just a minute short tracking on the board due to which any of the electrical component supporting the volume settings is got blowed out.you just require to open the unit and replace that faulty component from the board.and this will clear the problem.if not familiar you can get it dome by local electronics repair technician.its not a costly issue to get repaired if a short circuit or a internal button problem. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 09, 2009
What causes audio to suddenly increase to maximum?
Volume in modern systems are controlled by a single IC. If that goes, it makes the volume functions go wonky. The IC can be found by tracing the wires from the volume control, or following the circuit if it is mounted on a PC board.
Jan 29, 2016 | Audio Players & Recorders
Volume control
your volume control encoder is dirty and either needs to be cleaned or replaced.
Nov 10, 2013 | Memorex Nostalgia 4-way Stereo Shelf...
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
Toshiba volume increases by itself
This model do have a Remote Control right? Try to check that out... the remote could be the one setting the Volume up suddenly.
Mar 16, 2010 | Microsoft Windows XP Professional With...
Sansa fuza ....volume
Turn the dial while it's playing. Clockwise to increase, counterclockwise to decrease the volume.
Jan 26, 2010 | SanDisk Sansa Fuze MP3 Player
Sub seems to not get louder with volume increase. It seems to be overpowering at low volume or boomy then as you increase volume the front main speakers seem to take over.
Try adjusting the frequency cut off of the sub and also play with the gain control on the sub. Turn your system up to where your front speakers are sounding as you like. Then try adjusting the sub to match the fronts so you have a good balance and blend.
Aug 05, 2009 | Velodyne CHT-12 Subwoofer
Volume will just blast real loud
If you have a remote control , unplug the lead from the volume control (at the back of the machine) and instead of it plugging into the Inrfa Red control unit in the base of the cabinet, plug it straight into the amp volume input.
There has been problems with the remote that does what you are suggesting so this will prove the point.
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Denon AVR-1801 Receiver Logo
78 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
