Question about Sewing Machines
My video recorder won't let me insert a cassette. This happened quite suddenly. One day it was ok and the next it just refused to let the cassette in all the way
    Problem Solver:
  • 8 Answers
VCR's are complicated mechanical buggers relatvie to even a DVD player. There's a multitude different little plastic pieces, drive gears, etc. than can break or wear out over time to make the mechansim stop working.
15 Years ago VCR repair places did good business fixing them. These days no one bothers fixing VCR's so the ones that do exist, charge a ridiculous rate.
You will save yourself money and grief if you buy a VCR on eBay for ~$10.
Posted on Dec 09, 2009
Testimonial: "VERY PROMPT RESPONSE CLEAR EXPLAINATION"
I have a 1973 Bernina Record that I have been using quite regularly in recent months. It suddenly started running by itself. Is there a fix for this problem?
Generally, it is a problem with the foot control.
http://www.instructables.com/answers/How-do-you-fix-a-sewing-machine-that-wont-stop-ru
BTW, if the foot control has the number 213 on the bottom and there is not a "T" or "S" etched or label somewhere, these control units have a risk of catching fire. (The T or S indicates it has been repaired.) You can have the foot control repaired or pick up a replacement.
sewing machine running on its own Google Search
https://tv-sewingcenter.com/bernina/bernina-830-fire-hazard
Dec 21, 2016 | Bernina Sewing Machines
How do I remove the cassettes or cassettes from an Elna 7000? It stopped working after a power surge. I bought a used machine that works, but it doesn't have the 2 cassettes with the extra stitches.
The cassettes have a little tab you pull on which folds flat afterwards.
Disconnect from the power.
Open the cassette cover on the right side with a coin or with a screwdriver. Free the opening to the cassette housing by moving the slide downwards for inserting the upper cassette and upwards for inserting the lower cassette. (to insert, fit the cassette gently and firmly into its housing and fold the tab flat.) You will need to reverse to remove them. I've got a feeling they can get pretty firm when they have been in there for years, most people would add the extra cassettes and never remove them.
Aug 15, 2015 | Elna Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Won't operate. Won't go forward or in reverse, happened all of the sudden. Hand crank fine, but the whirring sound comes from that area.
it's possible that something in the machine has come loose or broken
it would have to be serviced at a sewing machine shop
Sep 23, 2011 | Husqvarna Prelude 370 Sewing Machine
Sewing machine won't raise the bobbin thread
Hi. The two main reasons why the top thread doesn't pick up the bobbin thread is either the needle is inserted wrong or the needle is bent. Since your machine was sewing properly until the thread broke, I'd be inclined to think the needle may have gotten bent. Sometimes this can happen if you sew over a pin.
Change the needle (making sure the flat side of the needle shank is inserted properly for your machine) and see if that solves the problem. Let me know if it helps, ok?
Robbie
Jun 07, 2010 | Singer Sewing Machines
My cs-8060 has quit automatically threading the needle.
Be sure that your needle is one that matches your machine, most are standered but check to be sure you don't have an off brand.
Aug 21, 2009 | Brother CS-8060 Computerized Sewing...
Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
Mar 23, 2009 | Husqvarna Viking 1
Broken needle threader?
Hi - welcome to FixYa. I have this machine, and unfortunately, the cassettes can break. If the threader worked when you first got your machine, I would suggest buying a new cassette (even if your threader is working). A second cassette is very handy because you can thread your next color in the extra cassette before the machine stops for the next color change - when the machine does stop, just put in the second cassette, and thread the other with the next color - speeds things up alot. And, if one of the cassettes does break, you aren't sitting in a puddle waiting for a new one.. You can find the thread cassettes for sale on a variety of sites - this is where I buy mine:
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Store_id=492&page_id=17
Some of the 270Ds came with a spool pin - look in your manual for a picture and for the instructions for installing and using the spool pin. You can use it for spool of thread that are too large for the cassette and I think you can leave it installed on your machine all the time. If you don't have your manual, leave a comment and I'll look mine and check the instructions.
Hope this helps. If you have a minute, a rating (good or bad) tells me if the information or solution I provide is helpful to anyone who visits FixYa.
If you would like me to write a tip on salvaging an embroidery project that has been pulled into a birdsnest, leave a quick comment and I'll add the tip. Thanks everybody, and good luck. Please feel free to comment if you need more help or have more questions.
Jan 18, 2009 | Brother SE-270D Computerized Sewing...
Bobbin
Turn Tension know to zero before inserting cassette each time hen insert cassette and turn knob to 5-6-
. worked like a charm
Sep 30, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
