Question about Verizon Communications enV2 Cellular Phone
I have the Verizon EnV2, & it won't charge. Is it my battery?
I have the Verizon EnV2, and when i charge it, it doesn't charge. The screen is black & doesn't say "Charging". Then i turn it on while attempting to charge & it says, powering down. Could it be the battery? I've had the phone for 1 year. How long do the battery's last for? Maybe that is the problem i'm experiencing. Thank you for your help.
  • tanisha_kell Dec 18, 2009
    This was exactly the problem with my cell phone. I took it to Verizon since it stopped charging, there was a short b/t the charger and the phone. They sent me a new phone FREE of charge. It wasn't the battery thankfully. Whew. Thanks for your posting & help! :)
Sounds like you have a short between the chrager and the phone... look and see if anything is bent where the phone and charger meet....if not.. call verzon your phone my still be under warranty and if it is they have to send you a new one ....of its just the charger they will GIVE you a new charger too
hopes this helps
Posted on Dec 09, 2009
Testimonial: "Thanks for your help! My phone did have a short b/t the charger & phone...verizon sent me a new one free of charge. thanks!"
When i Open My Env2 My Screen Started To Flicker
Somehow some moisture got in the phone take battery out of phone and let sit apart overnight and should go away
Jul 01, 2010 | Verizon Communications enV2 Cellular Phone
ENV2 Phone will not charge and its not my charger! help please!!!
Try another battery. Those batteries usually only last a couple of years.
Aug 14, 2009 | Verizon Communications enV2 Cellular Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
LG enV2 wont get past the black screen with the verizon logo
put a battery on it turnit on off on offf,,,,,if not throw it away!!!!!!!!!!!!
May 31, 2009 | LG enV VX9900 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
ENV2 got wet and now the verizon logo is all that flashes
i think you may have to get a new phone i had a friend who had an env2 got it wet and now it doesn't work at all. env2's don't like water
Apr 14, 2009 | Verizon Communications enV2 Cellular Phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
is it the right charger? if it is it may not be fitting good because the charger might not be good or the charging port on the phone take it to a verizon store.
Lg env2 not charging
The issue is the charger port on the ENV2 breaks fairly easily.The first step is to contact your carrier to see if it is coveredunder warranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparate from phone. cost about 25 dollars. Check out the following linkfor ones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
Hope that helps
Aug 04, 2008 | Verizon Communications enV2 Cellular Phone
Verizon Communications enV2 Cellular Phone Logo
429 people viewed this question
Top Verizon Communications Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Parshiv Luthra
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
