Question about Pioneer DEH-P9600MP CD Player
DEH-P9600MP not working
Hi iv had this unit about 2 yrs its suddenly started to go on and off i yhought it was wiring to h/u but this has been checked and all ok there is power to the h/u it now does not turn on after the face plate wouuld open so far the unit would turn off nowmit wont turn on at all...
ty
  • Anonymous Jan 22, 2008
    i think ive found out the problem ... its the power ribbon on the unit that may have worn due to the dual face on the h/u opening and closing so iv ordered a new ribbon
  • indygirl08 Mar 03, 2008
    Our stereo acts as if there is no power going to it and once in a while it will turn on and the face will slide down, then it closes again and thats it. Took it in and they said the motor is bad, we need to buy a whole new stereo...no way...this is only 2 years old....but we have no service centers anywhere near here...does this sound like it could also be a ribbon problem?? Any advice would be great!!
  • 2,042 Answers
Make sure our face plate goes in good snap in take a q-tip clean contact from radio to face plate hope its that cheers
Posted on Jan 19, 2008
6ya staff
SOURCE:
Deh-425 and deh-42 no speakers will work
hi ken, problem with your unit could be internal or external. i assume you not an audio technicain, start with checking all your speaker leads and speaker drivers directly, if any of these are found to be faulty try isolating it then retry to see if sound works again. secondly try resetting your unit. if all checks out well then you have an internal problem with your unit. check out your pioneer repair agent in this regard. remember if both units use the same harness(back plug) then chances are that you have an external problem with the speaker wiring or speakers itself. cheers.
Sep 08, 2013 | Pioneer DEH-445
After 2 yrs unused have decided to run in new dell
Did you plug in the scan unit and then installed the software?
If you did you will have to unplug or turn off your scanner then uninstall your software.
Reboot and the with the scanner turned off reinstall the software. If the install asks you to plug in your scanner, turn it on. If it asks you to reboot, then reboot. After rebooting, turn on the scanner then start the Easy Scan Utility. This should work.
It worked for me.
Jan 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Unit appears dead .prevously cured with a little wiggle , came with car , does it require a code before l check fuses , thanks Nick Mantle
pull the unit out and make sure that your connections are all good and solid -if you wiggled it and it worked momentarily- then chances are the wiring or wiring harness is loose and needs some attention
Jan 16, 2010 | Pioneer DEH-P9600MP CD Player
OEL display not working
YOU NEED TO REPLACE A RIBBON CABLE CALL 1 800 421 5080 IS A COMPANY NAMED PACIFIC PARTS THEY SELL THAT PART.
Mar 16, 2009 | Pioneer DEH-P9600MP CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
Missing Antenna lead
find an unused or broken stereo, and use the one off it
May 17, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer deh-p9600mp and deh-p960mp
my 9600 gat the same problem.. been told the ribbon needs replacing they sell on ebay for about £30 or you can send ur h/u to pioneer to do but that will be more expensive..
hope this helps
Jan 15, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer DEH-P9600MP CD Player Logo
184 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
