Question about Kitchen Ranges
I turn on oven and can smell gas for a minute,then hear it ignite
I have a frigidaire range glgf377csb. When I turn on the oven the glow lights up but then you can smell gas for about a minute. Then you can hear it ignite. It takes about 10 minutes for it to preheat.
I tapped on the valve a couple of times and it seems to work fine now.
Posted on Dec 10, 2009
Frigidaire oven FGB24L2ASA. Igniter glows red, gas turns on, but does not light.
I appreciate your inquiry, K Ogle!
From what you have described about your Frigidaire range the igniter glows red and the gas turns on but it will not light. It sounds like it could be a faulty burner or igniter and I would recommend having a professional come out to properly assess your range. This does not sound like a simple DIY job. Good luck. -Matt
Feb 17, 2015 | Frigidaire Kitchen Ranges
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
The clock(computer?)broke so I replaced that part it seems to work. I then tried the oven it will not light. The ignition glows red but does not light the gas. I can smell gas. I tried lighting the oven...
Just because an igniter glows, does not necessarily mean it is good. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
It sounds like you may have had a couple of problems. The gas smell concerns me though. If an igniter is weak, you shouldn't get any gas flow in the oven. This is a designed safety feature that prevents free flowing gas from filling up the oven cavity without ignition. I would recommend checking your igniter for the proper current and/or replace. The link I provided, lists the steps required. If you have any questions, please let me know. I hope this helps you.
Jun 25, 2009 | Frigidaire GLGF377 Gas Kitchen Range
Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
May 03, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Hello, I have a Frigidaire Range stove Model #FGF378WCCD. The oven ignitor heats but the oven doesn't light up and we smell no gas. What can it be?
if the ignitor may glow but if it isn't turning almost white it is not getting hot enough to open valve ,,,,, make sure it glows very bright and if not replace it / larry
Nov 29, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kitchen Ranges Logo
141 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
