Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Range - no display function
I have a GE Profile XL44 Dual Fuel Convection oven purchased in 2004. Yesterday as I was lighting one of the gas burners the digital clock display went blank/disappeared. Now, I can get no response from pushing any buttons on the display panel. I tried pressing the BAKE and BROIL HI/LOW buttons and the same time for 3 seconds, but no response. Also, I checked our circuit breaker and that was fine. The burners on the stove work, as does the electric light in the oven when I open the oven door, but I am unable to turn on the oven or get the clock display back by pressing buttons on the display. Please advise.
  • 1 more comment
  • MomAmyfix Jan 19, 2008
    Sorry...its a range, not just an oven.
  • corbs2008 Jan 27, 2008
    I have the same Model with the same issue. All of a sudden the only thing on the display is :0
    Last time I used it was for a timed bake.
  • abusymom Feb 02, 2008
    I have exactly the same problem -- the digital displays and oven went out sometime this last week, but the oven light is on, as is the gas range.
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
  • 1314 Answers
SOURCE: GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
  • 521 Answers
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Posted on Aug 12, 2008
RescueTech
  • 145 Answers
SOURCE: Bake ignitor Location
Hi Kurt, welcome to FixYA!
In the diagram below, Part #28 is your ovwn ignitor. (See the red markings to highlight it)
It is located underneath the oven floor, and the floor should come out by removing the two screws located in the bottom rear of the oven cavity. Take out the racks, take out those two screws, and lift the oven bottom up from the rear, then disengage the front lip and lift it out. I hope this is helpful info and thanks for allowing us to be of service to you.
a16646a.jpg to you.
Posted on Dec 23, 2008
  • 126 Answers
SOURCE: Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Posted on Jan 16, 2009
We have a GE Profle XL44 Self Cleaning Dual Fuel Convection range that just started displaying an error code "F0". What is the issue? Can the oven/stove top be used while assessing this...
Hi
F0 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
-AGK
Apr 17, 2011 | GE Profile JGSP44 Dual Fuel (Electric and...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 stove digital display clock stop working.
We see this failure due to two possible problems with the electronic control. Sometimes there is a failure that causes the display to shut off. Other times the display itself goes bad. The first case we can repair. If you send us the board we can check it out. If it is not repairable there is no charge. - www.fixyourboard.com.
Sep 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Jun 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
222 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
