Question about Helio Mysto Cellular Phone
My screen turns off when I slide the phone open fully. Please assist. It functions up until it hits the stop, then turns off.
Dial / Answer functions
anytime an update is done on an older phone it usually crashes..bite the bullet and get a new phone..
Jan 28, 2014 | LG Optimus Black Smartphone
DOES IT SLIDE OPEN
Motorolla L71 do not slide open, it is a flat phone that has all its function keys and screen on the front casing.
Motorolla L71 does not slide open., It is not a flip phone or slide phone.
Take care.
Jul 19, 2010 | Motorola Mobility L7I Cellular Phone
9 sciphone. the screen, has barely any function. the part where to slide to unlock, i can't get it to slide. somtime it will slide but then it won't unlock.
Hi, The touch pad on your screen is weak and does not function properly again, that is why you can unlock from the sceen. Needs to be replaced, it happens most times when a phone drop the flow or hits somewhere.
The only solution is to replace it with a new one.Thank you.
Take care.
May 20, 2010 | Dual Electronics CECT P168 Cellular Phone
PLEASE HELP! my tmobile G1 has been acting strange all day since I turned on phone. The phone went into safe mode now I have I'm in the bootup and it tells me to press home and back to reboot, and it wont...
so when your phone boots up in safe mode, it will only give you the ability to menus without any connection to wireless networks. you wont be able to view any apps or surf the web....
to fix this turn off the device and while its off, press and hold MENU and RED keys at the same time until you see the home screen
if that doesnt work, try to reset the device. i think thats what you were previously trying.....
when the handset is off, press HOME and POWER KEYS at the same time until a triangle with yellow "!" appears. release keys and slide open the keypad. press "ALT" and "W" at the same time until phone reboots. attempt to log in again.
good luck! :)
Dec 10, 2008 | HTC G1
No lights in the touchpad when slide up
its probably the sensors inside your phone. most manufacturer uses magnet or sensing... if you can open your phone check if its still in place... if not visit your service center...
Oct 24, 2007 | LG KG800 Cellular Phone
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Helio Mysto Cellular Phone Logo
66 people viewed this question
Top Helio Cell Phones Experts
Computer Repairing
Computer Repairing
Najwa Ahmad
Najwa Ahmad
Are you a Helio Cell Phone Expert? Answer questions, earn points and help others
