Question about Canon i860 InkJet Photo Printer
Waste ink tank almost full how do you empty it
    President:
  • 2,306 Answers
Neither has a clue! there are no torx screws on a Canon printer, and if you could get the absorber replaced, you wouldn't have access to the service mode to reset the counter. It's a shop repair.
Posted on Dec 30, 2009
  • 27 Answers
It isn't an easy task! First of all you need to know how to remove the cover from your printer. This normally comprises of two Torx screws which are evident on top when you open the lid. after removing these you would need to flip open several plastic latches around the base of the printer which hold the top cover onto the frame.( You may have to disconnect the panel cable from the op panel as you remove the cover - don't forget to re-connect it when you replace the cover later!)
Once done, the Cartridge cleaning station is to be seen under where the cartridges park when not in use. In order to get to it you will see a white plastic wheel (Low on the RHS ) which puts the Cleaning Station through it's cycle when driven by it's motor.
Remove the connector to the motor and, with a small flat screwdriver engaging the notches in the wheel, push the wheel round until the cartridge holder is free to move to the left along the carriage, clearing the Cleaning station.You will find a small Torx screw either at the front of the cleaning station (Seen as a plastic box/tray with felt pads in it) or at the RHS of the station. Remove this screw and then push the station towards the rear of the printer frame and lift from the front at the same time. It should then lift out towards you. ( You would be well advised to be wearing a pair of surgical gloves at this time, cleaning stations are particularly messy!) and don't attempt this operation on your best table cloth!
Having removed the station you can now remove the ink soaking pads, in order, empty the tray and soak the pads in an alchohol solution to remove the ink.
(Lightly soapy water may do the trick if no Isopropyl Alchohol is available. Don't use the best Vodka! What a waste!) When the station is cleaned up you can just put everything back in reverse order.
Good luck.
Any problems get back to me.
Cheers
Ian
Posted on Dec 09, 2009
  • BionicBilly Dec 16, 2009
    Who the hell is yahousewife?????
    She hasn't got a clue!
    Get her off here!
    New Friend:
  • 99 Answers
It solve only utility software.www.canon ip 1500 service tools.com.download it and solve your problem.
SOURCE:
Waste ink tank near full
You have to remove the waste toner bottle and put empty bottle.
May 26, 2011 | Canon Office Equipment & Supplies
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Where is a waste ink i have error message says WASTE INK NEAR FULL help me on that, thanks
I have had this problem. There is a counter in your printer that must be reset to move on. The ink tank may not be full, but the counter estimates it is full (and maybe it is an instruction to you to buy a new Canon printer), and to actually empty the ink tank would be an uneconomical task. How do you do it, there are a number of helpers here so Google: MP730 waste ink near full.
Apr 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Reload the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
WASTE INK TANK NEAR FULL.
see solution to INK TANK NEAR FULL SMART BASE 360
Oct 21, 2008 | Canon SmartBase MP360 All-In-One InkJet...
I get an error message on Canon i960 printer that tells me the waste ink tank full. How can I empty this myself?
Read it all here.
Scroll about half the page, to:
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEMThere is explained how to get rid of the error message very easy, and how to clean the waste ink pad manually. The latter seems not to be necessary, though.
Mar 27, 2008 | Computers & Internet
Canon i860 InkJet Photo Printer Logo
481 people viewed this question
Clive
Clive
old marine
old marine
