Question about Sony Playstation 3 (PS3) Console
Hi I described my problem with my playstation 3 yesterday. I can't get a picture on my tv screen when i turn the ps3 on. I have tried it on different tv's, i have changed AV cables, I have changed pretty much everything. I noticed before that I got a green screen quickly flash up on the tv when i turn the playstation 3. Does this sound as if Im going to have to send it back to sony and get a replacement? Thanks
  • 3,741 Answers
Its the problem in the unit and it needs replacement.also this same problem occurs if the cables are not connected properly.the cables are good but if not connected tightly and properly then this same problem happens.so first remove and reconnect all the cables properly and recheck if still the same problem persists then its the hardware problem in the unit.and yes you will have to send it to sony service center and they will replace it for you. many users face this problem and service center replace the unit. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 09, 2009
Playstation 3 Help!!!
try bowing it out with air seems gpu is getting hot or use vacume to suck all dust out .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Aug 07, 2014 | Sony Playstation 3 (PS3) Console
Hi! I have a playstation 3 that I can`t get connected with my old panasonic tv from the stone age, around 1999. It has of course no hdmi. It is no problems connecting the playstation 2 on the same...
Hold the power button down as you turn it on until you see something on the screen and it should bring up the default screen resolution. If you are using the PS2's video connector, then it should work. If this does not work, you should try it on a different TV.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
My Playstation 3 ejects discs turns on and everything, but no picture shows up the screen just goes grey no picture or anything do you know what the problem could be
someting might be in your ps3 my did the sameting yesterday hope it help if u side someting bad about me **** u but if not don't take it the worng way
Apr 01, 2010 | Sony Playstation 3 (PS3) Console
I have no picture/sound with the av conn nor sound hd leads
i had the same problem today. All i did, was hold the ON button for 5 seconds. It shoulld adjust the cable settings. Hope i helped. Worked for me
Sep 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 and & DVD's
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
There are a few things you can try first. If your system was previously working but now doesen't show video. try to remember if you changed any settings on the ps3 or did anything with your television different, video mode ect. If you havent been able to get a picture the whole time your ps3 may be set for a different video mode than your currect set up. If this is the case try turning off the ps3, then holding the power button until you hear a few beeps. Each beep is the ps3 changing video modes hdmi/component/composite/s-video. try this and see if you get picture.
Hope this helps.
Apr 07, 2008 | Sony Playstation 3 (PS3) Console
Picture on tv isn't appearing and controller not connecting
The only easy fix i know is to turn the console off and then press the power button until you hear a second beep. Hope this helps.
Mar 15, 2008 | Sony Playstation 3 (PS3) Console
PS 3 20 GB no picture,
Is your yellow cable plugged in ?, maybe its broken.
or maybe you need a coaxial cable or an s-video cable.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
12 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
