Question about Kenmore Dryers
Gas dryer does not agnite - Start button will roll the drum but will not remain on when released. No fire/
    Sergeant:
    Champion:
  • 278 Answers
Howdy: Inside the dryer is the flame starting unit. Two solenoids with AC voltage turns on and fire up the unit. Take out the firing unit and a appliance store will test for nothing. (Sears) Good luck - Doug
Posted on Dec 09, 2009
SOURCE:
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
Old kenmore dryer, drum won't turn
Could have the motor frozen, (armature,bearings,etc) causing an overload on the circuit. Can you physicly move the drum by reaching in and turning it?
Feb 12, 2013 | Kenmore Dryers
Drum is having trouble turning
unplug the dryer before you start ,check roller & pulley or install dryer kit
Oct 18, 2017 | Kenmore 72972 Gas Dryer
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
Makes a humming nose when you press start
Gas Dryers may produce buzz when the solenoid opens. The valve clicks at the start of the heat cycle, start of ignition and when the burner turns off. The flame makes a low roaring sound.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 18, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Dryers Logo
52 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
