Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson works fine in the bare floors mode but when i turn it to carpet mode it makes loud noise and wont **** up.
  • 701 Answers
You need to replace the belt. Here is a link to the manual and to the belts you need:
Dyson DC07 Manual and Belts
Posted on Dec 09, 2009
Squeeling noise dyson 33
Is it when you go from carpet to floor or floor to carpet? It will make a loud noise detecting a possible suction issue. I've also had loud noises and turned over the vacuum and where the brush is, traps hair, thread, rubber bands, etc. Just take a scissor and cut it all out. Don't cut the bristles. Roll the brush as you cut and pull all the stuff wrapped around the brush. Once it is free, try it again.
Jul 27, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
While on the carpet setting- when the arm is released- there is a loud noise...doesn't matter if it is on bare floor or carpets-- if on the bare floor setting there is no noise on floor or...
I'm sorry to hear you're having difficulties with your DC14 Animal. The cleaner's brush control system is designed to make a ratcheting sound to alert you if the brushbar is jammed. Although you've already cleaned the brushbar, it's a good idea to follow the steps shown in our online support guide to make sure you haven't missed any obstructions in the cleaner head:
http://www.dyson.com/support/help.asp?article=650&product=DC14-ANIMAL_US
This should allow you to resolve your issue without further assistance. However, if you've checked the brushbar and cleaner head are clear of threads, hair, or other obstructions, but the cleaner still seems to be making the ratcheting noise, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 04, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Stripped gear noise occurs in carpet mode, not bare floor mode
Maybe the level to carpet is too low or there is more then one belt and one is broke?
Mar 26, 2017 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The knob that turns it from carpet to bare floors makes the head not spin for carpet It was a reburished one. bought in Nov 09
sounds like those wonderful people over at dyson installed the clutch and cover on wrong. it should be fine just use it oposite.
Dec 30, 2009 | Dyson DC07 All Floors Bagless Upright...
My brush bar won't turn - works in bare floor mode, but carpet brush won't turn when it should...
replace the belt the belt sounds like its worn or stretched the belts turn at high rpms and get very hot and soon just ware out they work fine on floors but when it comes to carpet they slow down, i hope this works out thanks
Nov 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I stop that annoying ratchet noise?
its your clutch tht has failed you will need to change it if you need to see how its done then log on to youtube and search for fit dyson clutch its all on there hope tht helps
Oct 14, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Aug 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Apr 12, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
324 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
