Question about Garden
I think there is something caught in the rotar - Ariens snowblower - it was running smooth then it jammed up. I pulled out a few soft branches wrapped around drive shft but I cant see anymore but it stills is not working.
    President:
  • 1,627 Answers
You need to check and see if it broke a sheer pin when it jammed,they look like reguler bolts and can be found in the tubeing that you see when looking at roto in the front.
Posted on Dec 17, 2009
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Ariens snowblower
Did you leave out a spacer out?
Feb 14, 2014 | Garden
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Snowblower starting problems
It is still jammed disasewmble if necessary.
Dec 17, 2013 | Garden
Recoil starter assembly
If you can post the engine make, model and serial number I can get a diagram for you. They are usually stamped in the engine housing. Start by removing bolts to remove cover and check spring. If spring is good you should be able to rewind. You will need to cut rope by handle and pull rope up between spindle and inner housing, rewind rope in direction of pull. Let it rewind while holding tip of rope. When satisfied with tension, push end of rope back through hole in cover and reattach handle. This can be tricky. I am thinking of posting a video of this procedure. Let me know if you have more question's.Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Dec 03, 2013 | Ariens Garden
Briggs & Stratton 11 horse snowblower engine pulsating
this i what my pressure washer does... I would say its just getting aged and you shouldnt have to worry about it, but if you want to try to get it to stop then give it a good tune up. spark plug air filter and clean the carb out with a small wire or tourch tip cleaner to make sure all the passages are clean and clear... or just let it keep doing it like I do.
Feb 10, 2013 | Garden
How can you start a Ariens 824 snowblower
Ignition key on, throttle three quarters on, full choke, press primer 3 or 4 times, pull cord. Should cough, maybe start and run rough, then as it's chugging, turn choke to half, then quarter choke, let it warm up slightly, then choke off.
Dec 05, 2009 | Ariens Garden
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
