Question about OKI Computers & Internet
No function no 24v only 17v - OKI Computers & Internet
    Brigadier General:
  • 10,406 Answers
Replace the defective power-supply -- there is nothing that an "end-user" can do to fix it.
Posted on Dec 10, 2009
What is the price of a battery for a drill Agojama 24V
I did have a Agojama 17v drill. I have searched high and low for a replacement battery but with no luck. The manufacturer is no longer in business. Their Dutch factory is closed. I wish you all the best in your search. My drill finished up at my local council's recycling depot.
Dec 05, 2017 | Drills
One red light flashes. I know the batteries are charged 17v. I've checked all connections. apmeter reads zero. What else should i check?
17 volts is a sign of one battery bad, or both. How old are the batteries? Check each battery separately for at least 12v. Check at the batteries themselves. If you don't get the 12 or greater reading replace the batteries. If you don't have insurance check at batterysharks.com.
Jan 20, 2015 | Pride Jazzy 1103 Ultra Standard Power...
How do i set maps for uk as it wont let me enter country name
Lynn-- I don't understand what you're trying to do. The Xantrex Statpower Prosine 1800 GFCI 24V 806-1850 is an electrical power supply inverter, designed to convert (usually) battery power (direct current) to house power (alternating current). How is an address applicable to this function?
Dec 28, 2014 | Xantrex Statpower Prosine 1800 GFCI 24V...
What is wrong with it?
FIlter capacitors in the positive supply are likely failing. These will be the larger metal cans- one may be bulging. Either way, one of them is shorting out after a certain voltage potential is achieved and causing your problem.
Replace the caps in both the positive and negative power supply sections and this should alleviate the issue. Match the working voltage rating, or even one step up in working voltage. yours are likely rated 25 volts, so a step to 35 volts would not pose an issue.
Apr 06, 2012 | Behringer MX9000 EURODESK 24 Channel In...
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
WHERE DOES THE ORANGE BLACK AND GREEN CORD GO?
Sorry,there is no "orange,black and green cords" on Logitech x-530 computer Speakers. Every RCA has it`s own color (yellow,black,white,red).It shouldn`t be hard to plug them in.
Nov 02, 2010 | Logitech X-530 Computer Speakers
New furnace humidifiera class 2 transformer marked 24V, 12VA
The 24Va 12Vac transformer should function as well. with absolutely no problem.
Feb 01, 2010 | Desert Spring DS3200 Humidifier
50 inch kf-50we610 SONY TV blinking light
Thats usually caused by a regulator having failed.or could also be a wire cable not connected correctly. Troubleshooting the power supply will verify if the +17V line is missing
Dec 16, 2009 | Televison & Video
My irC-3200 cannon just show me this error E012 number on the display screen so i want to know what this code mean??Please help me
E012-0001 Error code At about 37 sec. after the power is turned ON, due to a drum ITB motor failure
Symptom About 37 sec. after the power is turned ON, E012-0001 is displayed due to a drum ITB motor failure. Cause Rotational failure of drum ITB motor Items to Check 1) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR, enter 1 and press the OK key.
2) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR-ON, press the OK key to check whether the motor is working normally.
3) Check whether 24V is supplied to J93 on the ITB drum motor. If yes, the ITB motor likely faulty.
4) If 24V is not supplied to the ITB drum motor, check whether 24V is output from fuse PCB J70-3 to the ITB drum motor.
Also, check whether 24V is output from the fuse PCB J71-1 to the microswitch PCB and also whether 24V is supplied to the fuse PCB J71-2 from the microswitch PCB.
5) If there is no problem between the fuse PCB J71-1, -2 and the microswitch PCB, the fuse PCB is likely faulty.
If 24V is output from the fuse PCB J71-1 to the microswitch PCB and not supplied to the fuse PCB J71-2, check the microswitch PCB. Field Remedy Replace the drum ITB motor.
FH6-1971 DC Brushless Motor
Sep 01, 2009 | Canon Office Equipment & Supplies
Computers & Internet Logo
Top OKI Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an OKI Computer and Internet Expert? Answer questions, earn points and help others
