Question about JVC RX-8030V Receiver
FM muting When i turn the receiver on and go to my FM station , it show me that the Auto Muting is on. How do i remove that. On my AM channel all is ok no issue there. Can you advised me what to do. Thank you
4 Suggested Answers
SOURCE:
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Posted on Mar 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: auto muting on when on am/fm
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Posted on Mar 31, 2010
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
Mute light flashing
Is the amp otherwise functional? If not- check to make sure the speakers are hooked up and not shorted.
If it is functional and on AM or FM mode, it may just be the station signal is not adequately centered so part of the carrier is not being detected by the PLL and the between station muting is kicking in.
Oct 29, 2012 | Marantz PM-15S1 2-Channel Amplifier
Receiver comes on but have no sound tried the solution; but it still didn't work. What I am seeing is, in the upper left hand corner of the window in small writing says "mute auto" which is...
Mute Auto is for FM only. It mutes interstation hiss while tuning. Look for some other indicator that might reveal why the signal path is failing. Tape?
Have you tried the basics? Speaker test? FM only?
Sep 01, 2011 | JVC RX-554V Receiver
I have an older onkyo integra (TX-870) which pop when I change stations, then no sound. Need to turn off and begin again. Can this be fixed or should I purchase a new 2 channel sys?
Hi, It sounds like you are listening F.M. radio and the F.M. muting button is engaged ( as well it should be-otherwise you will have static between the stations ) sometimes there is almost a "THUMP" sound when you switch stations-this is caused by the receivers P.L.L. circuitry losing then locking in on stations, if you do not lower the system volume you will amost assuredly cause an overload of your final drivers, that's why it will come back on when turned off-it has reset. Turning off fm muting will get rid of the "POPPING" noise-it will however leave you with unbearable static which in turn should cause you to lower volume momentarily eliminating the need to constantly turn off the receiver. Thank for asking FixYa, I hope this helps, let me know how I did or if I can be of more assistance, good luck Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
The mute light Is on and the radio won't play. But if we play It threw the did player it works. How do I get the mute off for the radio?
If the MUTE is right next to the TUNED, it means the FM is muting inter-station noise until you tune a station strong enough to produce good audio. This has nothing to do with speaker MUTING.
Find FM Mode (page 14) and change it to Mono. Then you will hear the noise between stations until you find one strong enough. Install an anenna (page 3) and you might get strong enough signals to return the mode to Auto.
http://resources.jvc.com/Resources/00/00/96/LVT0141-001A.pdf
Jan 17, 2011 | JVC RX-558V
I tried restoring the sound by pressing Muting on master volume. Auto Muting still appears on the display and I can't restore the sound.
"Auto Muting" is for FM reception only and means it will mute the FM audio unless the signal is strong enough to provide decent audio.
Re-evaluate your symptom and corrective actions for relevancy.
Manual / Troubleshooting Page 31:
http://www.retrevo.com/support/JVC-RX-6000VBKJ-Receivers-manual/id/315bh050/t/2/
Dec 27, 2010 | JVC RX-6000V Receiver
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
Page 26:
AUTO MUTING
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
LXI tuner not working
Unfortunately without the make and model, there is little that we can do to assist you. There are too many tuner designs to be able to give you any useful information. Please try the unit in mono mode and with any "muting" turned off. If you receive stations with the muting and stereo modes turned off, the problem is with an I.F. amp stage. If you receive nothing, that is informative as well.
Please investigate a bit more and post the make and model and I should be able to assist.
Thanks,
Dan
Mar 13, 2009 | Audio Players & Recorders
Dec 03, 2006 | JVC RX-618V Receiver
JVC RX-8030V Receiver Logo
231 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
