Prewash programme stuck
I have a BEKO WMA510A washing machine. The problem i have is that when you press power on button the READY light comes on as normal however the PREWASH LIGHT is constantly flashing. I can not turn turn it off and the machine does nothing,can you help haynesy.1966
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Beko washing machine WME8227B. Switch on power, set programme ,press start button, hear the door lock (noticed that the padlock symbol isn't on as nomal) no water flows , checked manual eg child lock, time...
Probably a fault with the lock or latch; should be no problem for an engineer to fix. Just try giving the door a firm push to close it, to see if the padlock light comes on.
Jan 10, 2018 | Beko Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Sep 05, 2008 | Indesit W 123 Front Load Washer
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
WMA510W
Click on "washing machines" (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site!
Jan 06, 2008 | Washing Machines
Beko wma 1715s
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Jan 05, 2008 | LG WM1814CW Front Load Washer
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
302 people viewed this question
Top Washing Machines Experts
