Question about Maytag Neptune Washer
Maytag neptune mah3000aww
Neptune is not draining after 3rd rinse..
  • 1 more comment
  • G-Mike Feb 02, 2008
    drain hose had developed a kink or collapse where it exits the cabinet.
  • Ray21 Feb 18, 2008
    When I run the washer there is no drain cycle it is just staying full of water. I managed to remove the water and run it again same problem can someone help me trouble shoot this? Model MAH3000AWW
  • Anonymous Mar 14, 2014
    maytag neptune drain problem
    Problem Solver:
  • 8 Answers
Re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Posted on Oct 23, 2008
Everytime when I start the washing machine it shuts down water filling cycle within few seconds. Is something clogged? water filter(s)? Where are they?
Posted on Jan 31, 2008
Check the pump, mine the pump is not rotating, it just sits there and hums,
I hooked it up to 120 V (the 120v pump) and it sometimes spins, sometimes hums and sometimes flutters like it is trying to pump, it appears the bearings wore out after 15 years.
I found a new pump for it:
http://www.partstore.com/Part/Maytag/Maytag/MAH3000AAW/Maytag/Maytag/22003059/New.aspx
Posted on Dec 31, 2008
  • rudimentary Apr 16, 2011
    The water on my neptune wasn't pumping out and cycle basically stopped. I called out serviceman. He said it was the water pump and then quoted 280 dollars(australian) to fix. Amount was too much for me right now so I thought I would have a look myself. (I was a radio tech 20 years ago) unscrewed hoses and wires and pulled pump out of machine. Once pump was out peered into the inlet end out noticed one elastic band entangled in the pump impeller. Fortunately the pump was able to be diassembled readily and I disentangled the lacker-band. Put it all back in machine and Pump ...and machine now works fine....at least for the moment.
Volume resistor r-11 on control board
Posted on Apr 29, 2008
Probably the wax motor and control board problem. See web for information - subject of class action suite. Might want to buy a new washer
Posted on Feb 24, 2008
Maytag neptune washer
clean the dispensor where you put the softener and unblock the drain hole
May 08, 2013 | Maytag Neptune Washer Door Mah3000aww
Model#mah3000aww won't go into spin cycle...checked belt and its good.it rinses clothes but does not speed up when draining or go into high speed
take off the panel above the door,there is a micro switch next to the light put meter on switch and read it out,use a screw driver and push on switch while your checking for continuity,if that switch checks ok change out the enersia switch,take off just the right side of the boot and remove right side white cover and you can reach this switch
Nov 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH3000AWW washer will not drain
First and foremost unplug the unit
remove back panel
remove hoses from pump (expect water have towels handy)
open pump by removing screws
remove foreign objects if any
check impeller blades to ensure that they arent worn down
rebuild and reinstall pump
or replace pump reconnect hoses, replace rear panel
you should be good to go
Sep 10, 2009 | Maytag Neptune Washer
Maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
Jul 07, 2009 | Maytag Neptune Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
MAYTAG NEPTUNE WASHER SHUTS OFF (MAH3000AWW)
motor controller or motor, weigh the cost of the repair before comitting to the repair, new parts only carry a 90 day warranty
this could be a large amount applied to the cost of a new machine
Apr 11, 2008 | Washing Machines
Washing Machines Logo
1,304 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
