There is a P on the screen, the copier has paper, what does it means?
  • Adorjani Laszlo May 11, 2010
    Describe your problems and the copiers machine models.
  • Norman Davis
    Norman Davis May 11, 2010
    what is the brand and model number of your copier???
  • Office Equip... Master
  • 1,297 Answers
Please specify your machine models for help.
Posted on Dec 12, 2009
In screen say "p" what it means
It means,you'r out of paper.Check the sensor,which register if the paper is in casette
Oct 03, 2014 | Canon PIXMA Office Equipment & Supplies
C-3423
The error code means there is some thing wrong the fixing unit. I believe it for to many paper jams in the fixing unit. Remove all of the paper jams and to rest it > Turn the Main power Off and when turning the copier back ON, press and hold the utillity button till the screen changes and the Trouble rest show on the display screen. Press the "OK" and let it do it's thing & then turn it off and back ON. Good Luck
Jul 08, 2012 | Konica Minolta Bizhub c203 Copier
It will not copy, the screen shows a P and it smells like it's running hot. What is the problem?
When this copier can not find paper by pass tray or casset then show it p .P mean add paper.Before you select paper tray then make a copy.Thanks
Tareq Bin Mostaq
Bangladesh.
Aug 13, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a message on my display screen that says "unable to print 36" What does that mean and how do I fix it?
36 usually means that a paper is jammed. You will have to open it up and manually remove the paper.
Mar 22, 2011 | Brother MFC-845CW multi-function...
My copier is flashing J and will not run..........what does that mean?
"J" means you have a paper jam in the copier. I would look in the fuser unit and the paper path from the paper tray for a small piece of paper left over from a paper jam... Good Luck
Sep 11, 2010 | Minolta EP1031/1031F CS/PRO Copier
Shows paper stuck at screen and doesnt have
Have you tried pulling out the whole imaging unit?
Open the top cover and front cover to remove it.
Jan 20, 2010 | Copystar CS-1500 Copier
It won't print and it has a
PC stands for Paper Cassette. It means that the machine is not able to feed the paper from the tray. You need to check and or reload paper in the tray. If you keep getting the PC indication there is a problem with your paper feed system. Most common is the feed tire needs to be cleaned.
Oct 20, 2009 | Minolta EP1031/1031F CS/PRO Copier
I do not have a manual. What does supply REC. paper mean?
supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Dec 16, 2008 | Canon imageCLASS D320 Laser Printer
Workio DP 2500
means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Sep 23, 2008 | Panasonic Workio DP-2500E Copier
14 people viewed this question
k24674
jasbo
jasbo
