Question about HP Compaq Presario C304NR Notebook
Ram? how do i get my laptop to recognize new ram installed
    Genius:
  • 1,067 Answers
Should auto unless u installed to much or to fast not right speed ?
Posted on Jan 19, 2008
6ya staff
SOURCE:
Asus f450 doesn't recognize new ram
please try to swap in another slot and check if not so issue with RAM replace it.
Feb 16, 2014 | ASUS Computers & Internet
What is a ram? I need more detail so I can fix my asus laptop...
Ram stands for Random access Memory. It is essentially the short term memory of your PC. Looking up the specs on your laptop or Motherboard will tell you how much and what type is useable in your machine. Looking in the control panel ay"system" will tell you how much is already installed. Installing new RAM is easy by turning off your machine, opening the bottom of your laptop or side of your tower, Ground yourself (touch something metal) and unplug the old RAM plug in the new RAM. Restart. On restart your system will recognize the new memory.
Oct 17, 2010 | ASUS B50A-A1 P8400 Notebook
Memory upgrade
try to change slots of the Ram. Still if it's not working try only with new RAM to check if new RAM is working fine or not.
May 04, 2010 | HP Pavilion dv6245us (RP285UA#ABA) PC...
Has 1Gb Ram installed. Bios not recognizing dimm
was it new ram you bought or was it out of some other machine because it might be a caes of bad ram. try your old ram in the laptop and see if it boots up if so then get your ram chaged.
Mar 14, 2010 | Dell Latitude C840 Notebook
Toshiba Satellite A105-S1013 is not recognizing all of the RAM
Your gpu may share your laptops ram
confirm it with your vendor
Feb 15, 2010 | Gateway MX3215 Notebook
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
Have a -problem getting my gateway to boot and recognize a new 1g pc3200 ram card? what am i doing wrong?
1.It's low density ram, right? (Unbuffered, Non-ECC) The chip configuration is 128MB x 64?
2.When you installed it. The AC adapter was removed, (Charger), and the battery? (If you didn't the ram is fried)
3.You inserted the ram stick, (Module, correct speak), at a 45 degree angle, the pins were lined up, and when you pressed the module down, the locks on BOTH sides clipped into place?
Uninstall, and reinstall the ram again. Doesn't hurt, and only takes a few minutes. (MAKE SURE there is NO electricity to the laptop!)
After reinstalling the ram, reboot the laptop. Sometimes it takes 2 to 4 times before BIOS will recognize the new ram. This is semi rare, but it does happen.
If nothing avails, then you have the wrong ram for your laptop PERIOD! (Hope you didn't get it off of Ebay!)
Try using Crucial.com
Jul 09, 2009 | Gateway MX7118 Notebook
Laptop doesn't recognize new ram
I would guess that you need PC 133. Some manufactures that were using SDram at the time required PC133 while others would require but allow you to use PC100.
This is the requirement for your laptop from www.crucial.com
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot.*
Hope this helps
Apr 09, 2009 | Gateway Computers & Internet
I want to put ram in my laptop evo 1020v, but he recognize only 512MB how can I do. thanks you
When you say that it only recognizes 512 MB, I am assuming that this is after you installed the RAM?  - How much did you have before you installed it?  And how much did you install?
Sometimes it is as simple as making sure that the RAM chip is pushed in far enough.  Make sure the chip is pushed in securely.  Sometimes you will hear a click when it is in far enough. If it is not, the laptop will not recognize it.
Hope that helps.
Mar 09, 2009 | Compaq Evo N1020V PC Notebook
HP Compaq Presario C304NR Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
