Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Read only when I try to transfer my data to the HD I was promt as such : the item "MAC HD" could not be moved because "New Volume" cannot be modified.  When I checked, it states that it's "READ ONLY".  How can I reset it so that I can "Read and Write" Please advise.  Thank you.
4 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Copying data
click on the drive once so it highlighted. Hit the 2 keys apple and I. this will bring up a dialog box with the drives information. See if the drive is locked. Choose ownership and permission below and click on the padlock, you want read and write permissions and you will only need your system password to change this. Also check if the drive is formatted properly for Macintosh use. If there is nothing on the drive that is crucial, open DISK utility and format it for OS extended.
Posted on Oct 23, 2007
  • 31 Answers
SOURCE: can't transfer items to hard drive
Do you have vista? if so you need to have administrative access to add to the hard drive.
Posted on May 23, 2009
i have a 1TB iomega hard-drive - trying to store files from my mac pro, message i am getting "iomega HDD cannot be modified"
Please help!!
Posted on Mar 26, 2010
SOURCE: My toshiba calmee titan cannot be read modified with Mac
The hard drive needs to be either a) reformatted with a file system the Mac can manipulate (HFS+ would be ideal) or b) install MacFUSE NTFS-3G.
Posted on Aug 13, 2010
0 characters
1 Points
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
Feb 16, 2014 | Imation 160GB Apollo 2.5" Portable USB 2.0...
Help my hd just stop working
If the drive is external, you can try to remove it from its case and attempt to read in using another adapter. If the drive itself will not spin up a data recovery service may be your only option (usually expensive)
Nov 13, 2013 | Samsung 500 GB 5400rpm SATA2 8 MB Notebook...
Can i transfer information to a mac
If the external hard drive has been formatted on a PC in NTFS file format then the MAC cannot read data off this hard drive.
The FIX..
Connect the USB external hard drive to a Windows computer and copy your data off this hard drive to the computer.
Then format the external hard drive in FAT32 file format. (the MAC can read and write to data to and from a Windows PC)
Now copy the your data from the computer back onto the external hard drive.
Now you can connect the external hard drive to the MAC and download your data to the MAC.
Feb 22, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
Does not read on the mac
If the USB hard drive was formatted in NTFS on a PC then the MAC cannot read this hard drive.
If you format this hard drive on a PC in FAT32 file format then the MAC can exchange data between the MAC and the PC.
The MAC can read and write PC data to this hard drive.
Oct 15, 2012 | Buffalo Tools (HD-PE500U2/RD) 500 GB USB...
Hi, I am having problems transferring files from my macbook pro(never had this problem its like its locked out my laptop) to the hard drive it keeps telling me "The item cannot be moved because LaCie...
Yup because you formatted in NTFS yesterday on your friend's windows. only window pc's can write to the hard drive.
so you will need to reformat it under mac to mac extended.
or if you want to FAT if you want to write from both platforms.
please note that FAT file size is limited to 4GB's..
you could download NTFS write drivers for mac but it is unsafe and data can be corrupted.
Mar 11, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Try reformatting the drive using Disk Utility. Could be that the file system on the drive is not supported by Mac in read/write mode.
Feb 18, 2011 | Western Digital My Book Essential 1TB...
I opened the box just now, inserted it into my mac desktop and tried transferring a folder into it, it says: "The item could not be moved because freeAgent GoFlex Drive cannot be...
What I would be tempted to do is to reformat the hard drive of course THIS WILL WIPE OUT ANY DATA that is currently on the drive. To do this go applications then utilities and select disk utility. Once opened select your seagate drive from the left hand box and then select the erase option. Under volume format you can select Mac OS Extended and put an name in the name box. You can select MS-DOS (FAT) if you want to use on both PCs and Macs. Then click erase.
Hope this helps.
Dec 06, 2010 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Got a new imac moved ms office file to my book -
Try to change the File system of the hard drive to FAT. It is currently in NTFS. Mac recognizes NTFS file system as read only. You must use the disc utility and format it with a volume format of MS DOS.
By changing it to MS DOS (FAT) you can use it with Mac and PC. Readable and writable.
Aug 04, 2009 | Western Digital My Book Essential Edition...
Freezes up During Backups
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Apr 23, 2009 | Hard Drives
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
370 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
