32 tb westinghouse shuts itself off repeatedly. last time it happened unable to recall.
  • 10,515 Answers
This is a Common Problem on these Models. It sounds like Power Supply Board is going Bad. Most power supply's on the model set can be rebuilt by replacing electrolytic capacitors that have lowered in value.Most shops can rebuild the board for around $150 to $200.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 09, 2009
Blower motor intermittent failure
Change your blower motor resistor, common problem, where certain speeds will work intermittently and eventually complete failure. Located under the dash behind the glovebox. My #5 just quit working, I will be doing this tomorrow. My last TB, same thing happened. My neighbors TB same problem, only her female connector was melted that plugs into the resistor. My current TB is melted too, so I need to replace the connector and the resistor. This problem is so common in TB's and Envoys, it should be a recall.
Jan 03, 2014 | 2004 Chevrolet TrailBlazer
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
My lcd will stay on for 5 to 10 minutes and turn off the led light goes from blue to yellow
It goes into stanby mode (goes from Blue to Yellow) becuase it may have sensed over voltage or over current draw so it shuts itself down to protect itself. Most problem is either the power supply or the backlight inverter board. You need to inspect the two modules out.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
Apr 23, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My westinghouse 27 inch panel shuts off on its own but the front panel light stays on. You have to shut the tv off and turn it back on to macke it work again. It doesnt always work the first time
does it have any Eco settings, or auto shutoff after certain time settings. Not sure if they do anything about that, but there has been a handful of times over last couple years when my 32 in Westinghouse would either turn off, and not start, or simply not turn on. Had to uplug and wait a min a couple times. I have considered updating the firmware, but have heard so many horror stories about this on Westinghouse TVs I am afraid to try it. Just flashed new firmware onto my new Sony TV yesterday, no problems. Westinghouse has some funky issues with different hardware/firmware in same model TVs, and you have to turn off Autosource in power menu. So some peoples problem are probably cuz they didn't follow directions and bricked their tv. But some who suceeded and said it was easy no problem, still ended up with other new issues, and a firmware update is irreversible. If it only happens once in a while, I say live with it, or brave the firmware and give that a shot. I haven't tried Westinghouse support, but have heard it is less than desirable.
Drop me a line if ya want,
alchemancer@yahoo.com
Jan 20, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
My HDTV keeps turning itself off, and is random if it will turn back on. Sometimes it will remain off for hours. I also own another smaller LCD TV that will turn itself back on when I turn it off, this...
It sounds like there is a component on the power board that is going bad. What I would recommend to do first of all is to do a factory reset, you can do this by going on to the menu, go under the settings tab, and it wil be the last option which is the factory reset. If this does not work you will need to replace the power board. You can contact Westinghouse parts department at parts@wde.com.
Jan 14, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 32" TV randomly shuts off
It is a good possibility that you have 1 of your inverter transformers going bad. I wouldn't wait to have it looked at. It can cause more damage if the bad one let's go all together.
Oct 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Ford Freestyle Driver door will not close/lock in cold weather
There is a recall on this exact problem. I would contact your Ford Dealer. I recently was advised of the recall when I called Ford.
Dec 15, 2008 | 2005 Ford Freestyle
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Channel changing by itself.
I will tell you that westinghouse is the worst company among other brands. If you have warranty, return it and buy a sony or panasonic with a little extra money. It will help you later from buying another TV that is also as crappy as westinghouse's.
Oct 01, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
