Question about Zenith Z50PX2D 50 in. Plasma HDTV
There is sound but the screen is not coming in....there are just a few horizontal lines that come through...
  • 1 more comment
  • jmanwoodie Dec 11, 2009
    do u have a part number...I search for hd driver board and get no results...thank you
  • jmanwoodie Dec 12, 2009
    I understand it would be on the old part...I just dont know enough about this to know what that part looks like....when I google for hd driver board or image board I dont get anything...can you offer any help as far as identifying this part so i can search for it...is it called another name?
    Thank you,
    Jason
  • jmanwoodie Dec 13, 2009
    Well maybe I'm just not getting it but Im looking for a piece of information that will pinpoint the board....which board is it....I know what the y and z sus boards look like so those are out...if its connected to the tuner, what does the tuner look like? Is it in series before or after the tuner? Sorry for the trouble
    President:
  • Zenith Master
  • 1,114 Answers
The panel is bad. If it's still under warranty have it repaired, if not, replace it. The cost of the parts alone will exceed the cost of the TV at current pricing as well as locating the parts. Sorry for the bad news! It seems as though our electronics are becoming truly disposable when replacement parts are all but impossible to find.
Posted on Dec 14, 2009
  • Zenith Master
  • 3,866 Answers
This would be caused by a bad HD driver board.
1. you can repair or replace the driver board/
2. check for any swollen capacitors
3. Replace bad or swollen capacitors
you can purchase a new HD driver board from www.partstore.com.
I hope this information helps please do click the accept button
Posted on Dec 09, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Dec 11, 2009
    The number is on the old part it is product line specific meaning not all hd driver board fit your model but you can place a call to the manufacture give theyour model number and serial number with those two pieces of information they will give you a OEM part number that we just do not got on file.
    sorry to further inconvenience you at this time as this part number I currently do not have for your model.
  • Grand Canyon Tech
    Grand Canyon Tech Dec 12, 2009
    Jason.
    Try Decoder board, see people call it so many different names its not funny. Then I get cough up in the techno lan go passing the words on.
    People call it Decoder,Hd driver, and other non sense what it is a board connected to the display that drives the signal to it from the tuner. Now in rare cases the tuner is a part of the decoder so keep that in mind also.
    Thanks for your reply and I do hope you find it!!!
    Again if this information helps make sure you press the accept button or reply back to me Thanks.
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
No horizondal oscilation.
no line flyback transformer
vertical line horizontal out put circuit
horizontal line vertical output circuit
at fault
Sep 14, 2009 | Televison & Video
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
MITSUBISHI BIG SCREEN MODEL #VS55707
1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. IS the set shutting off or the hor. lines?
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Proscan PS35123-horizontal line only,sound ok
You have whats called a verticle swep falure. Its probably just the verticle output IC but if you dont know much about soldering or circuit troubleshooting ,you should leave this to the pros. Theres way to much Hi voltage inside these sets to twiddle around inside them. Also there are no consumer serviceable parts inside these sets as well, as they are all solid state, and my advice is spend a few bucks and get a pro to do this job for ya, as it can, and will, kill ya if your not careful.. Is it worth saving a few bucks??? Naawww Call a pro.. Good Luck
Jun 13, 2006 | Proscan PS32600 32" TV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
