Question about HP Compaq 6735s Notebook
Startup problem light's on but no display
I switched on the laptop and when start up it shows me all the light but it won't just start up and the screen will be blank... and the DVD light will be blinking continuously
    Problem Solver:
  • 5 Answers
Replace your ram to see if it works
Posted on Dec 10, 2009
4 Suggested Answers
nicoleFIXIT
  • 154 Answers
SOURCE: no display at startup but showing all lights
First we need to test if the problem should be the LCD screen. The easiest and most foolproof method for testing your lcd screen is to hook up the laptop to an external monitor. If the video output on the external monitor looks fine, this means that the problem is with the video connector, with your LCD panel itself, or with the circuitry that turns on the LCD.
Second we need to disassemble the laptop and find the video connector
on the system board (if the video is integrated on the motherboard) or on the video card that is attached to the motherboard. Try re-connecting the cables. You may as well locate the display connector on the back of the end LCD panel. Re-seat that one too. This way you can be sure that the problem is not related to connections.
Every now and then the switch located on the system board that turns the back light of the LCD on and off can become stuck. If this is the problem then your LCD never powers on. There's a little switch that detects whether the screen of your notebook is open or closed. That's the one we're talking about. Try to push it down and hope it gets unstuck.
Disassembling the laptop to unstick this switch is an option, but sometimes you can get away with not taking it apart. Try lightly hitting that plastic switch. But wait, this isn't the only possible cause, unfortunately. Re-seat the other connectors and cables that are present around the LCD panel and the video on board (including the inverter)
nanbuenbrazo
  • 553 Answers
SOURCE: No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Posted on Nov 05, 2009
  • 561 Answers
SOURCE: i have dell insprion 1525 laptop. my dvd drive
Hi
Please can you try the following
1) Power in laptop
2) Continuously press the F8 key until a advanced startup menu is seen
3) Choose safe mdoe
4) Try CD in safe mode and see if it works
Regards
Shauqat
Posted on Apr 19, 2010
What the solution of laptop hp compaq nc6000 when turn on won't start up
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
Nov 13, 2012 | HP Compaq nc6000 Notebook
Sony vaio notebook won't switch on
Can you see any display from the screen? if its a new hard drive, with no Operating System the it show anything at all, try to insert a boot cd and boot from the cd
Oct 22, 2012 | Computers & Internet
Not able to start up my hp dv4-1124nr laptop. Giving me black screen all the time. Have tried options like removing battery, AC Adaptor and also memory modules. It is still showing black screen after...
Try hooking up an external monitor. If the external monitor is working and showing you what you are used to seeing, than you just need to switch the laptop back to it's regular display mode.
There is a key that looks like this
'o'
you need to press the function key and this key (usually f4) at the same time to switch displays.
Dec 12, 2010 | HP Pavilion ze2000 Notebook
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
I have dell laptop.Cursor is showing. caplock on
No display? but you have an mouse cursor showing? So you must have an display and it is locking on startup of the OS. Do you have an bootable cd? If not lets try to start it up in safe mode..
1: power down system
2: on power up hit the F8 key keep taping it till you get display saying startup in safe mode.
3: start up in safe mode no network.
4: if it starts up to an desktop then its an driver or software which you have installed causing normal startup to stop.
If it doesn't start in safe mode we will have to boot to an OS CD.
Let me know how these first steps go..
Feb 23, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
No display at startup but showing all lights
Dec 09, 2009 | HP Compaq 6735s Notebook
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Startup display problem P100 PSPA3E
Hi, ok clearly for the symptom of what describes modal to his portable , I understand that the fault of his equipment comes from the card of video, which not this on board but it is separated, if the problem that he presents also happens for the VGA port and for the DVI port, this indicates that the problem that his equipment presents into in the system board.
Dec 06, 2008 | Toshiba Satellite P100 Notebook
HP Compaq 6735s Notebook Logo
239 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
