Question about Insignia IS-LCDTV32 32 in. Television
Sound and bright go to max. Remote and set buttons do nothing
  • 834 Answers
This is a common problem with these units the mainboard cpu looses a ground inside the ic so you will need to replace the Mainboard and you shoudl be able to get one tho9ugh BestBuys parts site
Posted on Dec 09, 2009
Remote RMT 10 - How do I get a picture while I have sound.
It's probably your TV and not your control. If you can turn the TV on and off with the remote, turn on the TV and press the setup or menu button on the remote. If your TV is capable of displaying a picture, you should be able to see the menu items. If no menu items are visible, it is highly likely that the TV is toast. If you can see the menu, then there is a setting on the menu that is disabling your video. It may be that you have selected an alternate input, or possibly dimmed the brightness to the point that the screen is black. Work with the settings - you have nothing to loose, it isn't working anyway. If you can find a master reset, select it and it will reset all settings to the factory configuration.
Jan 19, 2015 | Westinghouse Televison & Video
Tv volume stuck on max, volume + signal stuck, button is fine.
The problem is on the board with the controls----if remote receiver is not on same board disconnect that board--if it is unsolder the vol and channel buttons--the front buttons have priority over the remote--buttons will look fine but the switch under each will be your problem---better hope it is as only other cause is a microprocessor gone mad.
If you have a Ohm meter I can tell you how to prove this--going to have to get at the buttons--if you want to prove it is or is not a issue with the micro switches you are going to have to unsolder or test them.
SD TECH
Apr 26, 2012 | Televison & Video
Volume display on max on my 47
What likely is wrong if volume is at max and cannot turn down--the volume down button on the set is bad---seen this and to say the least irritates me.
The buttons on the set each engage a tiny switch--a momentary one--means only should react when pressed but they fail in exactly this way.
Remote is number 2 in line--that is to say the buttons on the set have priority over the remote control.
Only way to prove this is gain access to the vol up button/switch and unsolder the switch (two pins).
If set now is normal (thank god) you can either leave the switch out or replace the board with all the buttons/switches. Remote will still be able with defective switch out to operate sound.
If you think your problem is bad I have seen same issue with channel up and down buttons--always it is the switch.
SD TECH
Apr 25, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
Alba TV LCD4288DF 1080P Sound but no picture. On switching on get a very brief flash of the picture then screen goes blank, tried on all inputs with same results. It did sort its self out for a while but...
1. Check to see if the TV power outlet has power. Plug a lamp or something small into outlet to test for power. If there is no power in outlet, check your circuit breakers or power fuses.
2. Check to see if you have pressed the power button on the TV or on the remote controls. Check to ensure batteries are placed in remote correctly.
3. Check the setting of the picture brightness or contrast.
4. Check to ensure you have proper cable connections from your source going into your TV.
5. Check the volume settings on the TV.
6. Check to ensure the mute button is not pressed on.
Jan 20, 2011 | Televison & Video
Suddenly no picture and no sound all three lights flashing
First make sure to hit the menu button on the TV's remote and if nothing is there then while the set is ON turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost of backlights is around 150.00 and power supplies around 100.00.
Mar 21, 2010 | Samsung DLP HL-P5663W 56" TV
Can't adjust the setting (color, brightness, contrast, etc.)
It sounds like you may have issues with your main board
Nov 24, 2017 | Hitachi 27FX49B 27" TV
Panasonic Projection TV
6.1. How to enter SERVICE 1
1. In sound menu, set BASS to MAX, and set TREBLE to MINIMUM.
2. Simultaneously press INDEX button on remote control and
VOLUME DOWN button [ - ] on the TV set.
6.2. How to enter SERVICE 2
1. Set the channel to CH99.
2. Press HOLD button on remote control.
Jul 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Controls
Press and hold the menu button (either on the remote or the display itself). Other forums have said you only have to hold it down for 10 seconds, but that isn't accurate. I had to hold my menu down for about 30-45 seconds to unlock the OSD.
Aug 25, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Insignia IS-LCDTV32 32 in. Television Logo
63 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
