Back to:
Tags:
Technics DJ Headphones
Repair of Technics DJ headphones (by 2 users)
posted by mrjtburns on Jan 19, 2008
how do I get into the headphone shells in order to rewire them ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by DJ23, posted on May 20, 2008
Anybody got a diagram or even detailed instructions on repairing these headphones? I stood on the cable and that was that. I promised myself that i would never do that but i did! 100 quid down the drain.
Best Solution
posted on Jul 06, 2008
FixYa! (100)
dj jagged
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
hi dj23 Ive have the same problem with mine but i was lucky to find the screws that undo the headphones their are just behind the right hand side headphone under the black bit that touches your ear theirs 3 screws hiding behind the coving with little arrow marking their they are but be very careful as you open it up as the wires are very bake able in side as their is not much room to get in their to fix them i am still trying to work out the best way to put a new wire on to them as the wire that comes with this headphones are not fixable as its unsleved and its the string in side the outer flex that stops the wires touching each other good luck it fixing them please let me know if you get any other info luck jagged
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Repair of Technics DJ headphones:
I don't want to Accept this solution
Solution #2
posted on Apr 30, 2008
Helpful (85)
djproaudio
Rank:Guru Guru
Rating: 88%, 146 votes
Not an easy task. Actually, not an easy task at all. You have to be cautious when doing this, as you might damage the headphones, and once damaged, there aren't very many parts available for this particular model.
- TERMiNAL OPTiC
www.DJPROLAB.com
Thank You!
Can you Help with these Headphones problems?
Headphones
when i talk in the mic everyone says my mic is to loud an...
Headphones
Hi, I've got a ClearChannel Pro USB headset that has...
Headphones
i have just got the box super and i am having proplems...
Headphones
do i need a disk to get omega headpones hpm15 to work if...
Headphones
x box 360 headphones will not work with sound
Loading problems.
Repair Service
Find Headphone Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
