I have a 63" Toshiba rear projection TV. There is a line in the picture. It actually appears that the glass is cracked, but the problem is actually inside.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
A MODEL NUMBER WOULD HELP A LOT--I will make an educated guess.
The easy thing to check is (with the set unplugged!) remove the set's back cover and look up from behind at the screen---most likely thing is you are going to see a spider web across the inside of screen--
If this is the case the simple way is to use a swiffer type duster and reach up and remove it--do not apply force to it as you can scratch the inside of the screen.
Let me know what you find and if this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 09, 2009
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
Hi , i have toshiba 43" rear projection tv, the picture is not stable and bouncing all the time and the colors are oufull mainly blue red and green, what can it be ? are the lamps are finished ? the...
I would like to view that short video clip to diagnose possible cause of picture problem and would you please confirm model number of tv that would be written at rear?
Thanks.
Apr 29, 2011 | Toshiba 43A10 43" Rear Projection...
My Toshiba 42H83 has developed a color problem. The color blue is about an inch off the other colors, the picture looks like a 3d movie without the glasses. I have used the touch focus button on the...
Alot of rear projection t.v.'s have a convergence option in the menu on the t.v. There you can set the try to set the colors back how their supposed to. Mine has a cross in the middle of the screen and you just have to try to get all 3 colors to line up. Unfortunately, the actual lens inside mine has to be aligned so it doesnt work. Just something to try though, hope it helps.
Jan 05, 2010 | Toshiba 42H83 42" Rear Projection...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Picture goes out when floor jars the TV.
Check for bad solder connections around where the tuner attaches to the chassis. Look for cracks with a magnifying glass solder should appear shiny with no circular cracks.
Feb 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Appears that lint is on one of the lenses
this could be a contaminant inside one of the lenses, or possibly spider webs inside the tv.. This is a very common problem. Remove the back of the tv, you will be able to look around the back of the screen with a flashlight and see if there are any spiderwebs. at this time you should also clean your lenses and mirror with some glass cleaner . this will improve your picture as well.
Nov 05, 2007 | Toshiba 46H83 46" Rear Projection...
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
