Question about Magic Chef Dishwashers
Magic Chef DISHWASHER - mODEL du4k, STOPPED DURING drain cycle
Magic Chef dishwasher - Model DU4K; stopped during drain cycle, has power and I don't know what to check. I can take it out so I can get at the bottom where all the parts seem to be, but need to know what part may be bad so that it doesn't drain?? Thanks, Geo
I am assuming that the pump motor is bad, and since the unit is at least 15 years old (just guessing), we decided to wash the dishes by hand till after the holidays!!
Merry Christmas
Posted on Dec 10, 2009
Whirlpool dishwasher DU1015XTXBO Stopped working during cycle, acts like don't getting any power. Checked the plugin and it works. No lights or anything coming on the dishwasher. Its like it just
You may have power, however if a circuit board fails, all the power in the world won't start the washer. You need a technician to test the circuit for internal damage.
Feb 17, 2018 | Whirlpool Dishwashers
DU2100B: Looking for a repair/service manual for this. My problem is that the dishwasher will fill with water, then immediately drains. It rarely does a complete cycle without doing things out of...
I don't believe that a service manual exist i have included a image of the parts breakdown for the pump asm. and while taking look at it i believe the the drain solonoid is hanging up,or the drain flapper in the pump asm is hanging open The solonoid is shown is that image as item #5 it connects to the drain flapper shaft item #13 and the actual flapper is number is item #34 and has a sping thats suppose to close it item #35
one of those is staying open not allowing the water to stay in tub on wash cycle
http://www.searspartsdirect.com/partsdirect/part-model/Magic-chef-Parts/Dishwasher-Parts/Model-DU2100B/1429/0130000/X2905652/00006?blt=06&prst=0&shdMod=DU2100B
Good luck,i hope i have help you to figure out what is wrong with your dishwasher.
Gene
Aug 13, 2011 | Magic Chef Dishwashers
Water does not go into the dish washer during the wash cyle. This is a new problem on an existing Magic chef dish washer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Magic Chef Dishwashers
Dishwasher will run throght the cycle. But no water will flow
Sounds like you need dishwasher water inlet valve. This part is electrical and lets water flow during the wash/ rinse cycles. Unplug the appliance before attempting this repair. Part costs about $25 depending on model. This part is located under the bottom front panel and should be easy to replace even by someone with little experience. Should be two screw mount and two wires with slip on and slip off connectors. Easy!
Jan 16, 2010 | Magic Chef Dishwashers
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
My 14 yr old Magic Chef Model DU4K seems to be leaking (it is dripping into the basement just under where the dishwasher is located). it started when the arm at the bottom of the dishwasher did not seem to...
Being 14 years old I dought if spares are still available for this machine personally at 14 I would rather replace the unit if you are not in a possition to replace it you could advise from your local appliance repairs as to weather parts are available and what the cost is of parts for the unit before you decide to possible throw good money after bad (spend money on something that has very possibly seen the end of its life)sorry for the bleek outlook but reality is that old machines such as this seldom are worth repairing.
Jan 23, 2009 | Dishwashers
My whirpool dishwasher model du930pwps2 stopped working
sounds like the fuse on the control blew. you can replace the fuse for around $20 or you can cut and splice the wires for free. If that doesnt work then you may have a loose conection in your junction box under the dishwasher.
Dec 01, 2008 | Whirlpool 24 in. DU930PWP Built-in...
DIshwasher doesn't drain or fill
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Sep 29, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Dishwashers Logo
253 people viewed this question
Top Magic Chef Dishwashers Experts
jeff5may32
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
