I was cooking and the keypad on the stove locked up and oven will not respondI was cooking and the keypad on the stove locked up and oven will not respond
You can't post conmments that contain an email address.
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Hi I Have A GE XL44 That Is Running Very Hot I Want To Know How To Troubleshoot Because When I Was Cooking Plantains I Did Burned My Fingers Because Of The Oven That Is Running Too Hot
A blown oven element is possible. You may still be able to bake but the oven will seem to take forever to warm up. An easy check would be to crank the heat up full bore and put your hand near the top then the bottom. You should feel more intense heat the nearer you get to a working element.
If the oven is getting warm but not as hot as it should your thermostat is bad. They are a small pain to replace but can be done if you don't mind removing the front panel and removing 2 small screws. It would be best to get your model number and remove the thermostat to get exactly the same one. Let me know how it turns out. Ken
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Most modern
gas ovens and many broilers use a "glow-bar" style of igniter that
glows red-hot to ignite the gas. If the igniter doesn't reach the
proper temperature, the gas valve won't open. You may need to replace
the igniter.
