Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Power & fan issue
Power on and off repeatedly and fan funs constantly
how can I download the recorded shows to another box or to PC?
  • 374 Answers
Officially I am bound to state that there is no way provided by Dish Network to make this possible via the ports on the receiver. If you own the receiver you could take it to an electronics repaairer that could possibly repair the power cycling issue. If this is done with a leased receiver it will void any warranty you may have on that piece of equipment.
Posted on Aug 28, 2008
Why dose recording in dvr goes on default date when light goes
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
Dec 18, 2016 | Televison & Video
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
Just bought a guf 500gig freesat recorder. Seller tells me it should be switched off at nights. Is that True? Also he tells me it is normal for the internal fan to be running constantly whenever it is...
No,the box dosen't have to be require turning it off at night.Yes the fan is constantly running,when have on power to it.No,the box have intermittent problems,it not normal for the box to lock up and shutting u out of the tv programs.If the thing still under warrenty,get a replacement box.
Nov 27, 2010 | Grundig Televison & Video
I purchased hunter fans for my home. over the past few days i have noticed that two fo the fans that were installed are having the same issue. when power supply is turned on to the se two fans the lights...
this is usually caused by the watt governor or black box to lights. just remove box and wire lights directly. this will fix problem. have a good day !!
Nov 18, 2010 | Hunter (25417) Ceiling Fan
I recently had a new power supply installed in my compaq presario SR1318NX, now the fans run almost constantly. The air from the fans does not feel hot, nor does the tower. Is this serious?
In a desktop computer the fan is supposed to run constantly otherwise the processor would get that hot the system would repeatedly shut down or even damage the processor or motherboard.
If the fan is noisy then chances are that the fan blades need cleaning of dust.
Other than that you have nothing to worry about.
Regards.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
I have a JNC digital concept power voice II
The part which shows the files to be downloaded from the JVC recorder does not open when the software starts up. It only opens when the recorder is detected attached to the USB port. I suggest 1. Start the software. 2. connect the JVC recorder to the PC with the USB cable. 3. Turn the JVC recoder ON. The recoder display says "PC link" and the files to download show up in Power Voice II on the PC. Michael C
Sep 30, 2009 | Audio Players & Recorders
I'm having a truly bizarre issue with my tv! THe
First of all , your TV is good,the DVR from that company are bad. the solution will be to replace with an other brand of DVr and see if the problem still there
Sep 12, 2009 | JVC HD-61FH97 61" Television
DVR records blocks for 4-6 hours
If you have no manual timers with extended timers then replace the unit. That will eliminate the issue. Thanks for using Fix Ya.
Jul 03, 2009 | DISH Network DVR-625 DTV Receiver /...
My thompson dtr box will not turn on now.it stays on an amber light and doesnt want to do anything else.1day it was fine,now its not.
Message taken from TopUpTV
Does your Thomson DTi6300 fail to power on normally and displays a solid amber light? During the past few days we have been made aware of an issue affecting a number of our customers with a Thomson DTi6300 box. Customers have been experiencing problems with their box failing to come out of standby mode and typically showing a constant amber light on the front panel.
This fault is due to a broadcast issue which  has led to a corrupt file being loaded onto the hard disk.
Only Thomson DTi6300 boxes have been affected. If you have been experiencing problems of this nature first of all try switching your box off at the wall and leave for twenty seconds. If this does not work, please try the following procedure.
Please note this will unfortunately cause recordings in your programme library to be lost which we?re very sorry about. You may have to try this procedure a few times in order to resolve the issue as it requires complete attention and precise timing.
1.       Disconnect the power supply from the unit by removing the power cable from the back of the box.
2.       Wait 20 seconds and then put the power cable back in while pressing the 'standby/power on' buttonrepeatedly on the front panel of the box.
3.       Release the standby button as soon as you see a light flash on the front of your box and thenimmediately press the arrow buttons on the front panel quickly and in the following sequence:  Up, Down, Left, Right (please note this is not the order the arrow buttons appear on the box).
4.       Your box should then show the amber light with the green light flashing until the disk re-format has been completed which will take around 60 seconds. The box should return to a solid red light (standby) automatically. If after 2 minutes your box still does not display a solid red light, please repeat steps 1-4.
5.       When you return to the TV GUIDE screen, you will now need to scan for channels to restore your Top Up TV channel logos. To do this, please select Option 4 (set-up) from the Main Menu, followed by option 1 (scan for channels).
6.       IMPORTANT: Once you have completed your channel scan, you will need to select option 5 from the Main Menu (Choose your channels) to re-select all those channel providers you would like Top Up TV to download shows from.
We?re really sorry if you have been affected by this issue and greatly regret any inconvenience this may have caused.
May 06, 2009 | Televison & Video
Thomson DTI6300-16, The amber light constantly flashes, no red or amber lights appear! any help/advise would be welcome
May 04, 2009 | Televison & Video
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
210 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
