Question about Lenovo 3000 C100 Notebook (S5374971) PC Notebook
Fan required for a lenovo 3000 C100 as it make a
Fan required for a lenovo 3000 c 100 as it make a horrible noise on startup onl, what model fan do i need and where sell them in uk
  • 942 Answers
If you are in us, you can call our lenovo parts hotline at 1-866-428-4465 . If you are in uk check out our site
www.lenovo.com then click United Kingdom English, then click contacts, and find the appropriate number for your fan model...
Posted on May 10, 2010
Describe your Lenovo 3000 Y410 Laptop Computer - Intel Core 2 Duo T5450 1.66GHz, 802.11a/b/g Wireless, 2GB DDR2, 1 PC Notebook Problem.Buzzing noise from left bottom corner
Welcome to Fixya.
The system fans are located at the bottom left of this laptop. If there's noise, then it means that the fan is working to cool down the processing. If the fan noise is too loud, then it needs to be replaced as soon as possible.
You can check for replacement/repair options through Lenovo's support site :
Lenovo Consumer Support
Thanks for using Fixya.
Feb 19, 2011 | Lenovo 3000 Y410 Laptop
Laptop make buzzing noise low to high it goes. click on speaker icon it stops for a min but come back again and keep buzzing left side bottom corner .
Hi There and Welcome to Fixya.
This on and off buzzing noise in the system indicates that the fan is not operating as designed and needs to be replaced as soon as possible. You may refer to Lenovo's consumer support site for replacement/repair options:
Please understand that this kind of work requires a certified Lenovo technician in order for it to be completed.
My Lenovo 3000 J Series switches itself off at startup before the opening of Windows xp. Any ideas? This message is from another pc.
the problem of power off after startup can be caused by:
  1. a Faulty ATX power supply (the power good signal was not prperly generated to the motherboad)
  2. Cpu fan problem, the CPU temperature is abnormal
  3. faulty motherboard
to solve this problem, first change your ATX power supply unit with the same power rate. then clean the radiator and the fan. if the problem still not solved change your motherboad.
Dec 13, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
My lenovo 3000 Y410 is making a lot of grinding noise & also got very hot after working fr sm time
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Oct 31, 2010 | Lenovo 3000 Y410 Laptop
HORRIBLE NOISE!!
call tech or installer and check condensor fan assuming noise is outside. shut down outdoor unit and hand spin the fan blade to see if it is rubbing
Aug 09, 2009 | Goodman CKL24AR24 Air Conditioner
I find myself unable to use integrated camera in lenovo 3000 N100
Well, there are many things one can do. The most efficient way is to upgrade the CPU to a faster one and installing more RAM.
If that isn't a viable solution, you can also disable unused services that you may not require. More info on that here: http://www.pctipsbox.com/disable-unnecessary-services/
Also, be sure to do a scan for spyware with something like Spybot.
Lots of users report that by using Firefox instead of Internet Explorer increases their systems security.
Remove any unneeded Start Up items in your system tray. If you click on Start, then Run... and type in msconfig and then press OK, it will bring you to the System Configuration Utility. Click on the Startup tab and disable anything you don't need. It's easy enough to simply google a startup item listed to find out what the program does and then you can make a decision from there.
Mar 03, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My lenovo 3000 N100 model takes too much time to start.How can I overcome this problem?
U NEED to check two basic factores .,
ur system not be infected by an virus. so check it with a good antivirus.
and second is uninstall useless programes from add and remove program place because it waste alot of processing power.
Require Audio Driver for Lenovo 3000 N200 type 769 dual-core
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP audio driver for your model laptop,
www-307.ibm.com/pc/support/site.wss/MIGR-39956.html
Feb 22, 2009 | Lenovo 3000 N200 Notebook
Formating My Lenovo 3000 J Series Tower
Try to boot a different cd, to determine whether the drive is bad or if the cd is bad. If it is the drive, you can try cleaning it or replacing it. If it is the XP cd, borrow one fro a friend and use your license, which should be on you unit.
The drivers could be down loaded from the Lenovo/IBM web site.
Sep 28, 2008 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Laptop switches of after 5 minutes when on ac power irrespective of power up mode
You may try to uncheck the box under my computer>right click> properties> advanced> startup and recovery.
uncheck the box for automatic restart.
try to blow a can of compressed air into your fan and heat sink channel.
then try to run windows update or go to update.microsoft.com to do so..
regards,
Ronald.
Aug 19, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 C100 Notebook (S5374971) PC Notebook Logo
172 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
