Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
DC14 dyson beater bar not working
My beater bar is not working and I feel it is the clutch, but I do not know how to remove it from the machine. Where is the best place to purchase a new clutch once it is removed. thanks, Gary
  • Anonymous Jan 25, 2008
    My Dyson DC14 beater bar is not working. I cleaned all the debris from it, but that didn't help at all.
  • stephjime652
    stephjime652 Oct 26, 2012
  • 372 Answers
Manuals for removing & replacing clutch are available from here,
If your in the UK spares are readily available.
Posted on Jan 20, 2008
The brushes on my dyson dc33 won't turn. I know the belt hasn't broke. Thanks SIMON
brushes on my dyson dc33 won't turn Simon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to repair Dyson DC07 DC14 DC33
Dyson Burning Smell Beater Bar Brush Stuck DC14 Not Working Easy Fix
Aug 02, 2016 | Dyson Vacuums
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Beater brush on Dyson DC14 getting no power
Hi There,
Alec from VacuumSpot here. The roller on a DC14 does not have a separate power supply the way it works is when the motor is running there is a belt that runs from the motor to the clutch and then another from the clutch to the roller.
As long as the floor selector on the front of the machine is set to carpet it will work when the machine is on.
Without seeing your machine I would suggest that there is something not quite right about the clutch. If I was to take a guess it would be that the clutch to motor belt is broken or slipped off. I have made a video showing how to check the clutch and the brush.
Dec 08, 2012 | Dyson DC14 All floors Bagless Upright...
Dyson vacum beater bar does not work
DC14 have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at which has some excellent info on dismantling and repairing a DC07 (the DC14 is very similar to the DC07), but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Oct 04, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
We have a dyson dc14 and the beater bar stopped turning, we cleaned the bar off and checked the belt and it's not broken, I know I called Dyson a year or two ago and they told me how to reset the beater...
Hi its Darran at Dyson.
Check that the brush control dial is in the centre position when the machine is locked upright. When you release the head and pull the handle back this dial should mopve forward to the on position. Once here, the brush bar should turn.
If this doesnt resolve the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Dyson Customer Service
Mar 31, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My older Dyson DC14 (the purple one) early model with a clutch on the beater bar belt needs a clutch replacement. The bar has been cleaned and there are no worn or damaged parts so I conclude that the...
Have a look at which has some very useful info on dismantling and repairing Dysons.
Although this site doesnt actually cover the DC14 yet, the DC14 is very similar to the DC07 so as regards dissassembling the machine, and replacing the clutch, my experience is that the DC07 info will enable you to do the job.
Mar 26, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beater bar does not turn. The belt is fine.
The "switch" that turns the beater bar on and off is called the clutch. It doesn't often fail, and for you to have two fail would be exceptional bad luck - so this may not be the problem. You are aware, of course, that the beater bar is always off when the machine is upright. The clutch automatically switches to "on" when the handle is lowered (unless the clutch knob is in the permanent off position). Sorry if this is stating the obvious, but we get lots of Dysons in for repair where the only problem is the clutch knob is in the wrong position. You say the belt is fine - but there are two belts. One goes from motor to clutch, the other from clutch to beater bar. The motor-to-clutch belt is replaceable (but you can't even see it without removing the clutch cover), while the other belt is integral with the clutch unit and the whole thing must be replaced. The trouble is... even to replace the motor-to-clutch belt you have to remove the clutch from the machine and that's quite an involved job. If you're considering doing the job yourself, look at, scroll to the bottom of the page and look at DC07 clutch replacement, and that will give you an idea of what's involved. Good luck!
Dec 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal belt clutch slips.
The clutch problem needs to be looked at by a serviceman or professional who can repair Dysons. Slipping belts are often a sign of being overused or with carpet/textures that have caused the beater bar extra tension. I suggest if this model means much to you to get it repaired.
Mar 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
682 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
