Question about Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
I have a Eureka 'The Boss Smart Vac'. The beater bar turns when there's no load on it, however when it's on the carpet it stops turning. The motor shaft turns however there's not enough friction between the belt and the motor pully to turn the beater bar. Is the belt simply stretched-out and needing to be replaced? Any solution?
  • 701 Answers
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Posted on Dec 09, 2009
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
Beater bar wont turn replaced belt didn't fix the problem
you may have to take the beater bar off and clean out the hair,and string off of both ends, thats where the bearings are.
Jun 21, 2015 | Eureka 5856BVZ Boss Bagless Upright...
Screeching noise from eureka bagless the boss 4d
replace beater bar belt, check and insure beater bare rotates freely with belt removed.
May 19, 2012 | Eureka 5849A Boss Bagless Upright Cyclonic...
I replaced the belt in our Eureka Boss Smart Vac, it still seems loose, it uses a type R belt. The beater belt still doesn't seem to turn properly and seems that it doesn't pick up very well when I use it...
Check to see that the beater brush is not frozen up. Pull the brush and clean it, spraying some WD40 on each end piece that holds the brush in place. Also be sure the belt is properly installed so that the brush turns in the correct direction. If the brush is not turning or not turning in the correct direction, it will not beat the dirt from the carpet so that it can be picked up by the vacuum's suction.
Oct 01, 2010 | Eureka Vacuums
No suction power on my eureka boss vacuum (vacuum bag has been changed)?
Most probably a clog in the neck. This is where the power head connects to the body of the machine.
Remove the base plate (screws in). Take a look at the back of the head behind the beater bar. There is likely something blocked in the neck of the unit. Clear it out and you will likely me OK.
While it is open take the time to remove anything wrapped around the beater bar.
Good luck, please rate this answer if it helps.
Mar 29, 2010 | Eureka Boss 7601 Bagged Upright Vacuum
Eureka the Boss Power Plus belt problem
it could be the beater bar (brush) has bad bearings at the ends or burs on the beater bar section the belt rides on,my money is on the bearings.
Jan 24, 2010 | Vacuums
I have a eureka the boss smart vac petlover vacuum and I cannot find the book on how to replace the belt. I have opened it up, but there is a silver roller that is confusing me.
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
Oct 10, 2009 | Vacuums
Can't figure out how to get the belt around vacuum motor shaft
I am assuming you are referring to the beater bar belt. You will either find a release lever on each side or a small screw and bar restraining the bearing that holds the bar in place. Removing whichever of these you find will allow you to install the new belt. Clean up the dirt accumulation on the bearings while it is apart.
Dec 31, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka The Boss Smart Vac, beater bar stops turning when you use it on carpet
It is a simple fix that you need. Your belt needs to be replaced. After a period of time, the belt stretches to the point where it is still strong enough to spin the brush when you have the machine upside down to look at it, but when you put the machine down on the carpet the belt is too weak to turn the brush against the resistance of the carpet.
Most Eureka belt changes are simple to do and the belts are inexpensive.
Oct 24, 2008 | Eureka Vacuums
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
1,112 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
